Question about ASUS MB M3A78-EMH HDMI RT Motherboard
Error: unmountable memory
    Scholar:
  • 150 Answers
There is a good chance that you are trying to use the wrong type of memory with the board. Check with the manufacturer to make sure that it supports the type of RAM you are trying to make it use.
Posted on Feb 27, 2009
Camera says sd card unmounted wont work was working fine last night
In the settings menu under storage there is an option unmount sd card every time before removing the card from the phone or tab you should press this option unmount sd card otherwise directly removing the card without sectiong the option causes these errors
Oct 21, 2013 | T-Mobile Cell Phones
My Kyocera Rise has LOTS of problems! The one I want to ask is why do I keep getting a random message saying, "SD card has been unexpectedly removed"?
There are several possible reasons for this. The Kyocera Rise requires an SD card to be unmounted through the memory option in the settings. If you remove the SD without unmounting, you will receive the error message. The Rise also has several software issues that sometimes cause your SD to stop being read, even while still inserted. If you receive this error message without removing your SD card, it is recommended that you take your phone to a company certified Sprint store to have it checked out.
Jul 01, 2013 | Cell Phones
Am uzing lg p970 (red bull). i want to unmount my sd card because the gudget says sd card removed despite that i had inserted one
insert another sd card if the problem persists u take it to a hard ware repairer close to u
Oct 18, 2012 | LG Cell Phones
Error message card not initialized. It's been formated, and new batteries installed. what is the next thing to try?
Sounds like you pulled the card out while it was still uploading images to the computer, corrupting the card. So...a.- to try to recover the photos, you'll need photo recovery software, like digital photo rescue or others available via an internet search and...
b.- you'll need to put the card into the reader after you're done and reformat in FAT (not FAT32, not NTFS) so the card will be readable again in the S2pro.
What would happen is this: people would attach the card to the computer and delete using the computer. This can create a recycle bin on the drive. The next thing is that the card might be "unmounted," in that many people will just pull the memory card out of the reader and stick it into the camera without first unmounting the card.
This leave the card in an "open" state which the S2 Pro cannot properly read. The solutions:
1.- make sure there's no recycle bin on the card;
2.- plug it into your computer, and then properly unmount the drive using the taskbar, then pull the card out of the reader after you've been told it's safe to remove the card.
Since you describe a power issue as a possible initial cause, your final option is a new memory card. Also, only format in FAT format, since that's what the S2 Pro can see; not FAT32. You might also try formatting in another camera and then the S2 Pro.
Hope helps.
May 23, 2011 | Fuji FinePix S2 Pro Digital Camera
Getting "unmountable boot volume" error
Windows is totally corrupted - you will have to reinstall it. For that you will need an external CD unit and the recovery disk that came with the Mini. If you don't have it then you can either buy it from HP or borrow a similar XP install disk from a friend and use it and your key.
Mar 13, 2011 | HP Mini 1000 Netbook
Unmountable boot volume
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
Will not load windows I get an error message stating unmountable boot volume
i) i think you hard disk or hard drive(of your laptop or desktop) is malfunction or not working properly.....
   or it has gone bad, i think you have to send it for repair or replacement;
   error messge: unmountable boot volume is specifically for harddisk malfunction and requires repairing or replacement(strictly)
Thanking you
M. Sridhar
Dec 29, 2008 | IBM ThinkPad 600E 2645 Notebook
I/O Device error
First , i need to ask u if u try it on ur pc_usb only?
Sep 03, 2008 | Computers & Internet
Crash and Burn dell inspiron 8600 Help
Believe it or not, this sounds like a memory problem. Anytime you see an error of a page fault in a non-paged area, teh first thing to look for is memory issues. Can you move the memory stick(s) around? Try that first. Microsoft does not handle memory errors in certain areas very well. Sometimes moving the physical sticks around can place the bad memory cell into a less critical area that can be handled better.
Dan
Mar 25, 2008 | Dell Inspiron 8600 Notebook
Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Dec 13, 2007 | Dell Latitude D600 Notebook
ASUS MB M3A78-EMH HDMI RT Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
