Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Usr5450 robotics default ip address
I have use the AP model usr 5450, i need to access the AP so that default ip address is require, if any one help me i am thank ful to that person..
Ali
    Problem Solver:
  • 17 Answers
See review at http://www.wi-fiplanet.com/reviews/article.php/3088971
which says that the unit defaults to an "automatic" address (i.e., it's a DHCP client).If that's true, then you would have to set up the AP on a network that already has a DHCP server, such as on the LAN side of a wireless router. Apparently there is also a configuration utility that doesn't depend on the IP address, and can be downloaded from USR. See the product page at http://www.usr.com/support/product-template.asp?prod=5450
Posted on Apr 23, 2009
    Scholar:
  • 93 Answers
I don't know what you mean about 'so that default ip address is require', however to access your router/access point, the default address should be 192.168.0.1 for your routers configuration site, which you would type into your internet browser (internet explorer).
If it is not set at 192.168.0.1 for any reason, go to start>run>cmd and then OK. In the command prompt, type in "ipconfig". It will list you some addresses, Default Gateway would be the address to your router settings, enter that one into your browser.
Posted on Feb 27, 2009
  • Denis K. Feb 27, 2009
    If this isn't what you meant, please clarify.
I can't ***** my USRobotics Router after i reset
The model number you provided is not a router, it is an access point. As such, it doesn't have its own native IP address, it gets one via DHCP when you connect it to your network.
You should have received a setup disk with the access point that has a configuration utility. If you don't have the disk any more, you find the utility online at http://www.usr.com/support/product-template.asp?prod=5451. Use this to regain access.
Otherwise, you can login to your current main ROUTER and check the DHCP table to see which IP addresses have been assigned. You should be able to tell which one was assigned to the access point. If you cannot figure out which one is which, just PING each one successively, and the results will give you NAME of the device you are pinging.
Sep 07, 2013 | U.S. Robotics USRobotics USR5451 Wireless...
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
How do i change my wireless password.u. s robotics modem?
You can change password with below method.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 15, 2011 | U.S. Robotics MAXg USR5461 (738168036790)...
What is the default ip and user name, password for this model ????
The "IP address" is your DEFAULT GATEWAY so you can try 192.168.1.1 or you have to check it by going to START>RUN and type CMD in the box and then Enter (brings you to the COMMAND PROMPT type IPCONFIG and enter you will see your DEFAULT GATEWAY.
For the user name and password (you didnt mention the model #) so for all US ROBOTICS the User names are (unless you changed it) try "root" "Any" "support" "Admin" and Passwords are (unless you changed it) "12345" " Admin" "support" "password". If you did change it and cant remember you can always press the reset button on the back and restore it to the "Out-Of-The-Box" settings.
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Jan 06, 2011 | U.S. Robotics (USR5450) 802.11g/b Wireless...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
I forgot my custom ip address of us robotics so now how i can connect to it
The default address for that make and model is: http://192.168.2.1
If you changed the default address, you can perform a factory restore to reset the router.
To restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
Mar 20, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Help me to get default ip address
ok..
if you want fo find the ip address from the computer then click on start,then click on run and then type in cmd and hit enter,once you hit enter,you will see a black box in that box type in ipconfig and hit enter once you hit enter you will get the default ip address as well as the default gateway...
vedhick
Feb 26, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Two routers US robotics connected together
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
Dec 02, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Purchased a Compaq with a Broad com adapter
It is possible that USR is using mAC filtering as a form of security. Your new Compaq adapter has a MAC address. You can try getting the mac address of this device and input this on the USR
Oct 12, 2007 | U.S. Robotics (USR5450) 802.11g/b Wireless...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
3,693 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
