Question about Canon iR 2016i Black and White Copier
Canon ir 2018 ERROR CODE E246
When i turn on my machine, i see in LCD screen this code E 246.
  • 1 more comment
  • Nil Megouas
    Nil Megouas Mar 01, 2009
    I SEE THAT THERE ARE ANY PROBLEMME WITH THE CONNECTION OF THE CONTROLLER PCB OF THIS CANON IR 2018 ? I NNED THE TECHNICAL INTERPRETATION OF THIS CODE AND I SEE THAT
    I CAN DOING WHAT YOU SEE
  • Anonymous Mar 18, 2014
    during start up e 246 error code is showing
  • Anonymous Mar 19, 2014
    password misinge
    Sergeant:
  • 199 Answers
Check print controller pcb connection, ram & EEPROM
Posted on Feb 26, 2009
    Scholar:
  • 117 Answers
Product : CLC 1120 / 1150 Title : E246 Error Code Error :
E246 error code. This code indicates a problem with the counter board.
Workaround :
The error code may occur if the counter board malfunctions or if a counter board from a different machine is installed in the one experiencing the error code. The counter board must stay with the original copier. To rectify the problem call the Technical Support Center @ 1-800-528-2830 to obtain a new counter board.
or
imageRUNNER C6800
Title : E246 Error Code Problem :
After replacing the MN-CON pcb the imagerunner C6800 is rebooted and an error code of 246 is displayed.
Solution :
To resolve the  issue first verfiy all connectors to the MN-CON PCB and the Counter PCB are seated correctly. If the connectors are secure perform an MN-CON clear in service mode:
Copier>Function>Clear>MN-CON
Posted on May 07, 2009
My Canon PIXMA MX700 is not turning on! I have checked all the cords even moved from one outlet to another and its still not turning on. Should I just purchase an new one this model is an old on
Do you have a CD to install this printer? if you do go into MY COMPUTER where you can erase things and erase the printer and its system then shut computer off and restart then reinstall the printer using your CD to reinstall it. Some times you have to delete things and reinstall them to work.
Jan 09, 2017 | Canon Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
We have forgotten the Administration password for our EStudio 350 & 450. Is there any way of resetting? Thanks Ben
restart machine ,then press the 0 & 8 keys,enter 263, then press Start. You should see admin password on the screen.
May 05, 2009 | Toshiba Estudio 200L Copier
Canon iR 2016i Black and White Copier Logo
2,575 people viewed this question
old marine
old marine
