Question about Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
I am facing the problem with my power edge 1800 server scsi hard disk are not detecting and giving error
primary drive 0 not found
  • Tony Karavidas
    Tony Karavidas Jun 17, 2013
    Did you ever figure it out? I'm getting the same behavior now in 2013. I go into bios setup and it says the scsi controller is disabled by user, but I can figure out how to enable it.
    Novelist:
  • 148 Answers
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Posted on Feb 26, 2009
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
May 17, 2010 | Dell PowerEdge 1800 Server
I cant boot my server the hard drive can not be detected
Try taking the side off and removing and replacing all the hard drive leads. Remove and replace all the scsi drives and generally check for loose connections. If this does not work you will need to post more infomation.
Oct 29, 2009 | Dell PowerEdge 1800 Server
Dell server cont detect hard disk
chk for boot sequence in the BIOS and chk the hard disk is detecting in the BIOS
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Apr 29, 2009 | Dell PowerEdge 1800 Server
I have lost the scsi drive on a dell 1600sc and would like to convert to sata. During boot up the sata controller is reconizing the 2 hard drives but, come but with "no primary drive found"
The best thing to do is reinstalling SCSI, SATA can only manage two disk per channel on this server, and the data transfer time is longer.
If you set SATA, check jumper settings, that is probably reason why you get no primary drive.
Also check bios settings , do hdd auto detect and save in bios if you want to use sata.
If instead you want to go back to SCSI, download the drivers from the link below.
Download page from Dell.
Mar 03, 2009 | Dell PowerEdge 1600SC Server
Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Jan 21, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
1,023 people viewed this question
Alun Cox
