Question about Logitech Cordless Mouse
Easycall desktop and mouse i cant connect mouse. keyboared workng ok and no mouse settngs in logitech mouse and keyboard settings
  • Anonymous Mar 30, 2014
    connet and use my keyboard and mouse
  • 530 Answers
Hi im josh in cebu phils.may i help you friend? if the mouse wont work.there may be some problem on it. first check in the bios setting if the pheripherals mouse is enabled.enable it if not then check wether ps2 or usb is enabled it should be comaptible. try to see also in the my computer device manager if the mouse is present in connections. or try to check the connections in at the back of the cpu try to see if it is not loosen.firmly attached then reboot the pc.after rebooting if it still doesn;t work try to use another mouse if it works then the problem is your mouse try to secure new one. good luck. hope i helped you.
Posted on Feb 26, 2009
Will other Logitech mouse work with Logitech EasyCall Desktop?
Hi Warp you can not use any other mouse with your Logitech Easycall Desktop receiver, but with the additionnal mouse's receiver connected you should not meet any conflict using both at the same time. Thanks and have a nice day. Crenshow
Jun 06, 2010 | Logitech MX 600 097855036162
My s510 logitech keyboard and mouse aren't workng
instal this driver from here http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-ClickSmart-510.shtml and you're done.
Dec 09, 2009 | Logitech Cordless Desktop S 510
Logitech easycall desktop keyboard mouse combo...mouse connects, keyboard does not after replacing batteries???
Usually there will be a connect button, it sync them up together. First press the one and hold on the receiver then press the one on the keyboard. Sometimes they can be under/ on the bottom of the keyboard.
Sep 09, 2009 | Logitech EasyCall Desktop 967689-0403...
How do I change battery in Logitech cordless mouse
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=c*kceLDj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=3124&p_created=1145546604&p_olh=0
Jul 25, 2009 | Logitech EasyCall Desktop? Keyboard and...
My mouse and keyboard doesnt wanna connect.
did you install drivers? and did you install right from the cd provided
Feb 02, 2009 | Logitech Cordless Desktop EX110
Logitech easycall mouse works but the keyboard will not
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
Jan 30, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Wireless Keyboard not connecting
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
I put the USB plug in the two plug housings and the control immage on the screen still says "plug it in". It looks to me that my PC does not recognize my logitech web cam as it did in the past.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 03, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Keyboard works but the mouse won't work (starlogic wireless optical set)
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jul 06, 2008 | Logitech EasyCall Desktop 967689-0403...
Weird problem with easy call
If there is a dongle plugged into a USB port, try another port, i have a logitech wireless desktop, and it used to have probs when connected thru a specific USB port, also reinstall the drivers and check batteries.
Mar 31, 2008 | Logitech EasyCall Desktop 967689-0403...
Logitech Cordless Mouse Logo
113 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
