Question about HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor
Contrast and Brightness require adjustment
COMPAQ 1720 MONITOR.
I press the Menu button but cannot get a Menu on the screen.
Yesterday the contrast box - showing maximum kept coming onto the screen automatically - it has now disappeared.
The contrast and possibly the brightness require adjustment.
Maureen
  • Seabee Tim May 11, 2010
    Odd. Is this a new monitor? Did it come with an installation disc? Have you installed any new programs lately that may have caused a conflict with your display? A new game, maybe? What is your operating system and graphics card?
  • 530 Answers
Hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Posted on Feb 26, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
Dell 991 monitor
On the front of the monitor is a menu button. Press it, and using the left and right buttons on the monitor navigate through the menus until you see brightness, contrast, etc. Then adjust them as necessary.
Steven
Sep 17, 2008 | Dell M991 19" CRT Monitor
Compaq 7550
swede32169,
Try the buttons on the front or side of the monitor to get to the menu using the + or - to maneuver Thu the menu items until you see the "sun" that's for brightness the half filled circle is for contrast that helps too.
randy320sgi
Aug 13, 2008 | Compaq CV 7500 17" CRT Monitor
Hp pavilian f1703 monitor
Press the menu button again (or when done adjusting) and it will go away.
May 09, 2008 | CTX S762A 17" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Logo
252 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
