Question about Samsung SyncMaster 713N 17" LCD Monitor
Displayed "not optimized divice recomanded mode 1024x768"
Power on the lcd but it has displayed this error
  • Seabee Tim May 11, 2010
    Are you getting nothing besides that error message? No desktop?
Press F8 while booting and go to VGA Mode. Press enter key. This should solve the problem.
Saleh aldoseri Information Technology
Al Hala Muharraq Town
P.O Box 1538
Bahrain
Tel:- 00973 13681214
Posted on Mar 22, 2009
TheLCD is not working on resulution 1024x768 do i need any driver
Yes, it is very possibility of driver problem, but you can check it to attached with another PC. If the problem will persist you need to drivers. And another possibility is the LCD did not support 1024x768 resolution.
Good Luck
Mar 04, 2011 | Hyundai Electronics L19T+ LCD-TV 19"...
Hi i have a problem with my lcd screen.i have not use him for a long time (1 year) and now i use it on my new computer,after i connected all the wires i tried to open it and it showed me not optimal...
ok.. Since you gave me no valid information reguarding Manufacturer Names, Make and Model Numbers of the devices that you are referring to, I cannot get entirely specific on my suggestions to you.. But I can tell you this.. On BOTH DEVICES, (i.e. New Computer/LCD Monitor), go to the Manufaturer's Support Website and check for Current Updates per Operating System as well as Device Models.. ok?
Sep 12, 2010 | Computers & Internet
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Change the display resolution from 1024x768 to1024X1280
go to control panel > dosplay settings > click on the settings tab > click on the advanced button > c.ick on Monitor and tick the box that states "Hide Modes that this monitor cannot display > click the adapter tab > click on button "List all modes" This will list every resolution your monitor is capable of displaying.
Sep 17, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
WHEN I CONNECT TO THE INTERNET I GET A BOX IN THE MIDDLE OF SCREE
The recommended entry resolution is 1024X768... do you have your computer set to 800X600 or below ?
This is usually why you get this message.
go to control panel/display and check this.
Jul 29, 2009 | NEC MultiSync 1940CX 19" LCD Monitor
No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
May 29, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Display Resolution
samsung syncmaster 510N nonoptimize mode recomended mode :-1024x768 60hz how can i fix this?
Jan 19, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung SyncMaster 713N 17" LCD Monitor Logo
714 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
