Question about Compaq Presario M2000 Notebook
My Compaq Presario M2000 will not power up.
I recently changed the cd-rom to a DVD burner. After replacing that the computer powered up and found the burner. I then was going to upgrade the memory. I removed the memory cover, but discovered the memory I wanted to use was different. I reseated the cover and the unit will not power up. I plugged in the AC plug and the unit does not charge. Please help. Thanks Phil
  • philinpa Feb 26, 2009
    Thanks for your help. I will let you know how it goes.
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend if that happens that it will not turn on after doing such things I suggest to remove first your DVD burner and installed back your Memory.be sure it is seated firmly in its position try to see the marking on your memory and on your mainboard.then try to reboot your pc. after rebooting if it powers on so thats the time you go back again in putting back your DVD burner. Remember dont install your DVD burner unless your pc turns on to avoid misleading. try to do it bro. good luck hope i helped you.
Posted on Feb 26, 2009
Will an optical drive from cq62 fit mine?
NO.
I sort of see your reasoning, but NO.
HP Compaq DC7700 Ultra-Slim Desktop PC, and Compaq Presario CQ62 series of Notebook PC DVD burner drive?
http://www.ebay.com/itm/New-For-Compaq-Presario-CQ62-TS-L633-SATA-CD-RW-DVD-RW-Multi-Burner-Laptop-Drive-/300725349252?pt=US_CD_DVD_Blu_Ray_Drives&hash=item4604a0ab84
Until I compared both units I would have stated NO.
Now that I have THANK YOU. I just learned something,
http://www.amazon.com/HP-Compaq-DC7700-DC7800-DVD-ROM/dp/B004574PEG
Referring back to the photo view, of the Compaq Presario CQ62 series of Notebook PC's DVD burner drive shown, the REAR view shows the connectors for the SATA power cable, and SATA data cable.
The connectors use the same L-shape design, and size that a SATA unit for a desktop computer, would use.
Case design looks to be similar also.
I believe you are Correct.
For additional questions please post in a Comment.
Make all checks out to; The joecoolvette Fund for Having a Good Time
Regards,
joecoolvette
Oct 08, 2012 | HP Compaq Dc7700 Ultra-slim Desktop Core 2...
Cd/dvd rom not working
Check to make sure all ribbon and power cables are securely attached to the CD/DVD-ROM if it shows up in my computer and the device manager you will need to replace the driver.
May 14, 2012 | Compaq Presario 5000 PC Desktop
My computer can not detect a burner drive
Power off computer.
Take out power socket for burner drive
Make sure SATA/IDE cable is properly inserted. Clean them if they are dusty.
After powering up, make sure DVD driver is powered by opening the tray
Go in BIOS menu and see if it can detect DVD Rom there.
IF not,then you may have to check for Master/Slave config if you changed any hardware configuration recently.
Mar 12, 2011 | Compaq Presario 7596 (173952-003) PC...
My compaq says no cd/dvd found and its not even in the device manager
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don
Feb 22, 2011 | HP Compaq Presario F500 F700 and G6000...
Compaq laptop presario v5000 cd rom not working
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 24, 2011 | Compaq Laptop / Notebook Video-336970-001...
My c702tu dvd writer is not reading dvd's and cd
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
Dec 16, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Compaq presario 2500 notepad
Well,you already have a DVD burner in your machine, and A DVD ROM refers to memory.. you just need to download the upgrades available at Compaq's website. find out which Cd/DVD burner you have by downloading a marvelous freeware program called Belafrc Advisor, which will list all hardware and sofware on your
computer, compete with versions and access codes. then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=320163&lang=en
which lists all upgrades available for your model. DVD burners stopworking correctly when your non-microsoft burner program becomes corrupt, so be sure to upgrade that. If you have any problems, ask support.
Mar 10, 2008 | Computers & Internet
Dvd drive
Posdsib;y you will know when you have fitted it.
May 17, 2007 | Compaq Presario X1370US (DZ300U) (DZ300U)...
Compaq Presario M2000 Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
