Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Hard drive not working
Hi, I have this 2nd hd drive (8gb) that I want to add to my existing hd (4gb) main boot. But when I plug the 2nd hd as slave, the pc won't power on. Only the motherboard light works. I even tried to make the 2nd drive as the master with no slave but still nothing happens. Any idea?
celeron 633
samsung mb
256 mb ram dimm
lg cd rom
xp pro
  • 530 Answers
Hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Posted on Feb 26, 2009
PC w/ Vista. Can add 2nd drive with Win 7 and transfer all data & programs?
Try and get a disc clone software and use this instead.
Second, you need to set the jumper on the hard discs in order to configure your drives as either Master or Slave too.
Oct 07, 2017 | Computers & Internet
My WDC WD2500JS hard druive is getting noisy and slow. I am thinking of replaceing it before it dies and at the same time do a clean install of Win7. It is now XP. Can I make this drive a slave until I...
first up
uninstall a few unnecessary programs
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
second
yes you can make it a slave
you will have to change the setting in BIOS for master/slave aswell as the jumper settings
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
make sure the computers motherboard will support windows 7
wait until you get the new drive before before connecting your hard drives to master/slave
depending on the amount of drives your computer has you might have to change letters on all drives
naming of the hard drive you might be able to change the name opening windows explorer navigate to the drive then right click on the drive then select rename
Dec 15, 2010 | Western Digital 250GB WD RE SATAII...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Use second hard drive
The Windows operaring system is on your 1st drive (ie C drive) and if you change it to a slave drive the computer won't work.
You need to set the jumper on the 2nd hard drive as a slave drive and leave the original drive as the master drive expecially if the 2nd drive is on the same IDE controller and cable as the 1st. hard drive.
It doesn't matter if the 2nd drive is set to master or slave if it is on the 2nd controller.
When you boot up you should see both hard drives and can copy files from one drive to another.
Apr 08, 2009 | IBM ThinkPad R40 2681
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
Pc does not power on with hard drive plugged in
When you plug in the 2nd hard drive as a single drive does the drive spin up and the computer goes through the Power on self test (POST)?
If you cannot hear the drive spin up and the computer doesn't boot up then most likely the hard drive is faulty.
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Screen dies when booting up
TRY PLUGGING IN EXTERNAL MONITOR, THIS IS IF YOU HAVE A LABTOP AND I THINK NOT.
HOW ABOUT REMOVING THE OLD DRIVE AND PUTING IT ON THE NEW COMPUTER AS 2ND DRIVER OR SLAVE DRIVE, SOME COMPUTER CABLES OFFER SELLECT CABLE THE C DRIVE WOULD BE 0 AND 2ND DRIVE WOULD BE 1, IF YOU DONT HAVE SELECT CABLE THAN EACH DRIVE HAS TO BE SET UP YOU WILL HAVE TO GO TO THE MFG WEB SITE LOOK UP JUMPER SETTINGS, THE FIRST DRIVE WILL BE THE MASTER AND THE SECOND ONE WILL BE THE SLAVE, NOW IF YOUR CD ROM IS ON WITH THE HD THAN YOU WILL HAVE TO HAVE 2ND CABLE FOR THE CDROM TOPUT ON THE 2ND SET OF PINS MARKED 2ND HD OPTION AND YOU HARD DRIVERS MASTER AND SLAVE GO ON
BANK 0 IF IT SAYS 0, IF IT SAY1 THAN PUT IT ON 1.
REBOOT AND THE COMPUTER WILL START AND PUT YOU INTO THE CMOS AND YOU WILL ADD THE HARD DRIVE BY GOING TO 2ND HD PUTTING CYCL, HDS, SECT, YES LBA
2ND CABLE YOU SELECT CD OR DVD
F10 AND YES
REBOOT
EVERYTHING SHOULD WORK FINE.
IF YOU DONT FILL CONFERTIBLE DOING THIS TYPE OF INSTALLATION THAN HAVE YOUR COMPUTER PROGRAMER FRIEND DO IT FOR YOU OR COMPUTER TECHN WILL WORK TOO.
ROD
Jan 20, 2009 | Nvidia Riva TNT2 16 MB Graphic Card
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
1st and 2d eide conector on mobo
Hi, Does not really matter whether slave via jumper or cable select on the secondary IDE. Your mb will boot to whatever HD you set it at in the BIOS/CMOS as the first boot device. The 3rd drive will be recognized as secondary whatever and if your CMOS/BIOS is set right it will boot from the primary master on IDE1. Good luck and kind regards.
Oct 09, 2007 | Computers & Internet
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
