Question about Lenovo ThinkPad X61 Tablet PC
Screen rotate how do i activate the auto screen rotate on the x61 tablet ? thanks
    Scholar:
  • 61 Answers
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Posted on Mar 13, 2009
I have a connect tablet
Auto Rotation
  1. To open the Notification Panel, swipe down from the top of the screen.
  2. To stop the rotation, touch Auto rotate in the Quick Setting Panel.
  3. Depending on the screen orientation when touching the Auto rotate icon, the icon changes the screen to either Landscape or Portrait.
BEST OF LUCK !!!!!
Jul 30, 2017 | Tablets & eReaders
How go I rotate my tablet to vertical
1. Tap on the top right corner of the Home Screen to access the tablet > utilities.
2. Tap Settings > Screen.
3. Tap to deselect/select Auto-rotate screen.
Oct 19, 2014 | ASUS Eee Tablets & eReaders
How do i rotate screen on my tablet?
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
Aug 13, 2014 | Tablets & eReaders
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
Auto rotate
Sometimes there is a second option called screen lock that keeps the screen from rotating even though you have auto rotate checked. Check thru your setting to see if you can find this.
Jan 10, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
My tablet screen won't rotate
Make sure you have enabled screen-rotation in your tablet settings.
Nov 17, 2013 | ASUS MeMO Pad HD 7
Windows xp x41 migration vto x61
Have you tried just swapping the HDD into the new computer? The hardware might be similar enough for that to work.
Personally I would collect my files onto a flash drive, and start with a fresh install of the operating system on the x61. It will run much faster with a fresh install.
Nov 11, 2013 | Lenovo ThinkPad X61 Tablet
Lenovo X61 Tablet pen not functioning
Same here this sounds weird but you have to hit the screen with the pen.. in the long run it probably hurts the pc, but it fixes the problem.
Apr 28, 2009 | Lenovo ThinkPad X61 Tablet
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Feb 27, 2009 | Lenovo ThinkPad X61 Tablet PC
IBM X61 noteboot finger tip reader not functional.
if it says fingertip identification not installed then it means the driver is missing... try and install the driver....
Nov 06, 2008 | IBM ThinkPad X61 Tablet PC
Lenovo ThinkPad X61  Tablet PC Logo
2,693 people viewed this question
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
