Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Pc does not power on with hard drive plugged in
I have this problem, I want to add a second hd (8gb) to my existing main boot hd (4g). But when I plug the 2nd drive as slave, the pc won't power on. And if I unplug it, it works. I even tried to make the 2nd drive as master with no slave but nothng happens. Only the motherboard's light that is working. Any Idea?
celeron 633
samsung mb
256 mb dimm memory
lg cd rom
300 w psu
xp pro
  • HP Master
  • 32,281 Answers
When you plug in the 2nd hard drive as a single drive does the drive spin up and the computer goes through the Power on self test (POST)?
If you cannot hear the drive spin up and the computer doesn't boot up then most likely the hard drive is faulty.
Posted on Feb 26, 2009
PC w/ Vista. Can add 2nd drive with Win 7 and transfer all data & programs?
Try and get a disc clone software and use this instead.
Second, you need to set the jumper on the hard discs in order to configure your drives as either Master or Slave too.
Oct 07, 2017 | Computers & Internet
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
I have an 8GB hard drive with xp and i want to run my second hard drive 80GB off the 8GB
Set the jumper to cable select or slave and plug the IDE cable and power, you're done.
Oct 23, 2009 | HP Compaq Presario SR1920NX PC Desktop
Need to know where to hook up the card reader and 2nd HD. I have an ASUS M2N68-AM motherboard and I was looking for a schematic for this board to tell me where I can safely hook things up.
I assume you have an external card reader with a USB connector. If that's the case, you plug the device into an existing and available USB port, either on the front or back of your PC, or side or back of your notebook.
If it's an internal one, then you should find an available power connector from the power supply, and you will probably need to remove a plate in your PC case to install the device.
Regarding the second HD, any connector on the motherboard will usually only accept its own matching connector from the new device.
If your HD is SATA, then you probably need a second data cable, since the power supply comes with two SATA power cables.
It should be connected next to the existing and identical connector for your existing HD, assuming it's also SATA. It the latter it's an IDE type HD, then you should try to find a matching set of connectors (usually two), and attach the data cable to either one. It does not matter which one you choose in this case, since your PC is already booting from the IDE HD and will consider the second HD as additional storage, not as your boot drive.
Aug 16, 2009 | ASUS M2N68-AM SE2 Motherboard
Hardisk tidak aktif
likely have problems when the boot disk is .. try to see its boot settings and select the hard disk as its boot ..
possibility also exists on the power problems on the hard disk.
Jun 16, 2009 | ASUS Eee 4G Notebook
IBM T30 Start-up HD options
Why do you what to boot up from the 2nd hard drive?
If you want to boot up with a different operating system from a 2nd drive, I suggest you set up a dual boot system with the other operating system on the 2nd drive.
When you boot up you will be given a menu and you can choose which operating system you want. There is a time delay and if you don't choose a system it will default to the first operating system on the list.
May 20, 2009 | IBM ThinkPad T30 2366 Notebook
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Apr 04, 2009 | Dell Dimension PC Desktop
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Can't boot larger than 8gb hard drive
This is a known issue at HP, you should download and install the 68P4M ROM which will solve this:
- Fixes issue where system serial number was lost after upgrade to the new BIOS.
- Fixes variation in the noise of the fan when in motion.
- Fixes error where L1 cache shows only 16KB instead of 20KB in F10 Setup.
- Fixes error where FDISK could only see 8GB of 40GB and 60GB in the Multibay Hard Drive.
You can find it here :
Aug 15, 2008 | Computers & Internet
1st and 2d eide conector on mobo
Hi, Does not really matter whether slave via jumper or cable select on the secondary IDE. Your mb will boot to whatever HD you set it at in the BIOS/CMOS as the first boot device. The 3rd drive will be recognized as secondary whatever and if your CMOS/BIOS is set right it will boot from the primary master on IDE1. Good luck and kind regards.
Oct 09, 2007 | Computers & Internet
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
