Question about Lenovo 3000 C200 Notebook
Lenovo x61 hello folks ! how do i activate the auto screen rotate on the x61 in tablet mode ?
Windows xp x41 migration vto x61
Have you tried just swapping the HDD into the new computer? The hardware might be similar enough for that to work.
Personally I would collect my files onto a flash drive, and start with a fresh install of the operating system on the x61. It will run much faster with a fresh install.
Nov 11, 2013 | Lenovo ThinkPad X61 Tablet
My lenovo thinkpad x61 tablet does not turn on now. Replaced the battery 2 days ago, was working fine until today.
confirm that the Power adapter is ok if the A/C indicator comes ON on the LCD on the laptop. If the A/c indicator is off replace the the power pack. Else the board may be bad, replace the board.
Aug 12, 2010 | Lenovo ThinkPad X61 Tablet PC
I am trying to write to a CD on my Lenovo X61. I
buy usb dvd writer that include and cd driver / software, you can write anything on it.
Mar 25, 2010 | Lenovo ThinkPad X61 Tablet PC
How can I obtain a manual or the thinkpad x 61 pc
Hello
All the manuals should be available here
Hope this helps
Dec 07, 2009 | Lenovo ThinkPad X61 Tablet PC
Lenovo X61 Tablet pen not functioning
Same here this sounds weird but you have to hit the screen with the pen.. in the long run it probably hurts the pc, but it fixes the problem.
Apr 28, 2009 | Lenovo ThinkPad X61 Tablet
I lost my admin password for bios setup in lenovo x61 tablet
chk this link
http://www.tech-faq.com/reset-bios-password.shtml
or
most awesome answer is here
http://www.ja.olm.net/unlock/
Mar 30, 2009 | IBM ThinkPad X61 Tablet PC
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Feb 27, 2009 | Lenovo ThinkPad X61 Tablet PC
Screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Feb 26, 2009 | Lenovo ThinkPad X61 Tablet PC
Lenovo 3000 C200 Notebook Logo
153 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
