Question about HP Compaq nx6110 PC Laptop
My laptop, hp compaq nx6110 has a screen problem. Its dim
My laptop, hp compaq nx6110 has developed a problem with resolution on the monitor. Its dim and i can barely see anything. The function to increase the brightness on the monitor on the keypad is not working. How do i get to reset to default properties
  • sledgedk Feb 26, 2009
    I have followed all the steps in but the nx6110 has got no change plan settings hence no brightness meter. How else can i reset the laptop in the absence of a reset button? I am thankful for all the advice and efforts.
  • HP Master
  • 32,281 Answers
The problem could be a faulty inverter or the backlight fluro light lamp. The inverter is easier to replace than the fluro lamp.
Google the WEB for replacement parts and instructions on replacing the lamp. There are quite a few helpful sites for parts and repair instructions.
Posted on Feb 26, 2009
    Problem Solver:
  • 17 Answers
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
  • Seabee Tim Feb 26, 2009
    I forgot, when you go into your "Power Options" from the "Control Panel" and click "Change plan settings" there's a brightness meter right there.
  • Seabee Tim Feb 27, 2009
    I'll try the same fix from a different angle, if this don't work I'm at a loss.
    In your "Start" menu click "Control Panel". Make sure you're in "Classic View" (left frame at top) and click on "Power Options". In "Power Options", look at the left frame, should be the last option: "Adjust the display brightness".
Don't know why it won't work
You won't be able to. Your on board graphics does not support it. You would have to update your graphics card and with your laptop you are unable to do so.
Sep 29, 2013 | HP Compaq nx6110 PC Laptop
Compaq nx6110 laptop hangs after 30 minutes, please help
It should caused by a power supply too weak or not stable problem.HP Compaq nx6110 PC always happen to this problem.
Feb 10, 2011 | HP Compaq nx6110 PC Laptop
My screen dispaly only have two resolutions
Most likely only he generic VGA driver was installed.
Install the latest video driver for your model Compaq laptop.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jan 05, 2011 | HP Compaq nx6110 Notebook
How do i remove the screen from a cq60 laptop...I want to remove the screen and install a new one
This will require a fairly intensive teardown of the laptop. You will need to remove the battery on the bottom to get to the screws that hold part of the assembly and/or covers together. You will need to remove the keyboard and the switch cover that is above the keyboard, this piece hides the display mounts. You will need to disconnect the small video cable that is attached from the monitor to the main board. You may also have a wireless antenna cable that will need to be disconnected. You should now be able to unscrew the mounts and separate the monitor from the laptop. Reverse this process to install the new monitor. If you are installing a new monitor in the laptop's original monitor case, you may need to access several tiny screws around the monitor that are typically hidden under small sticky covers around the monitor. For an expanded walkthrough with illustrations, check this site http://www.scribd.com/doc/5988230/HP-Compaq-Nx6110 and look for section 6.19 Display Assembly.
Jul 18, 2010 | HP Compaq nx6110 PC Laptop
What driver do i need for i can get video on my projector i am using compaq nx6110
None. Connect the projector to the laptop using the VGA, open Start/ Control Panel/ Display/ Settings/ select the native resolution of your projector /Apply /OK. Now all you have to do is to drag the window of whatever you want to be projected there.
Jan 08, 2010 | HP Compaq nx6110 PC Laptop
Required graphics for compaq nx6110
Firstly ensure that you have installed the correct graphics drivers for your system. If Iam not mistaken your system has an intel chipset and graphics hardware. you can download the correct drives at intel.com or at hp.com. once you have done this you need to change your screen resolution to 1024 X 768 pixels, because movies and most games need this resolution to be your minimum in order to function properly. screen resolution is adjusted by right clicking on you desktop window, left click on properties and then selecting the settings tab located at the top right hand corner on the display properties window
Jan 20, 2009 | HP Compaq nx6110 PC Laptop
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
HP compaq nx 6110 blinking
try and connect a monitor to the external monitor connection at the back and check whether the same thing happens. probably it wont and this will mean that the screen is having luminosity problems and might need to be changed.
Aug 25, 2008 | HP Compaq nx6110 Notebook
HP Compaq nx6110 PC Laptop Logo
741 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
