Question about OKI B6200 Laser Printer
Oki b6200 paper jam
I have an error message on the oki b6200 saying 'pull out all trays. clear jam' and 'clear jam and close cover A'. Thing is it doesn't recognise the trays have been taken out, and there is no paper in the printer at all. I have powered on the printer without the trays in and still says to remove them, any advice?
  • 3 Answers
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Posted on Jun 30, 2009
  • 21 Answers
Restart the printer or reinstall driver again.
Posted on Oct 08, 2009
How to fix brother printer paper jam error
Follow the steps below to clear the paper jam.
  1. Pull the paper tray completely out of the printer.
  2. Pull the jammed paper up and out of the printer.
  3. Press the cover release button and then open the front cover.
  4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes shown below.
  5. Open the back output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7. After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  7. Close the jam clear cover. Close the back output tray.
  8. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
  9. Put the drum unit assembly back in the printer.
  10. Put the paper tray in the printer.
  11. Close the front cover.
http://support.brother.com/g/b/faqend.aspx?c=hk&lang=en&prod=hl5040_all&faqid=faq00000026_010
Sep 11, 2017 | Brother Office Equipment & Supplies
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Welll its not a canon but ew are in dire need. Our 16 month old OKI b4600 wont print.Error message says clear paper jam. cant find a jam swapped tray, cartridge/drum etc. No luck. Any suggested
Hi There and Welcome to Fixya,
Usually, paper jams can occur at the input location right at the bottom of the printer - always remember that even a tiny piece of paper can cause halt in printing, hence, the error message.
Here's what I'm suggesting for you to do :
  • Start with pulling out the tray from the printer and look for ANY crumpled/pieces/fragments of paper that could be tucked in.
  • At the bottom of the printer is the feed area - do the same thing and remove any pieces of paper.
  • Ensure that it's absolutely "paper fragment free" before returning the tray back at the printer.
  • Next, is to open the top cover and carefully remove the drum.
  • Remove any pieces or fragments of paper that you find.
  • Carefully slide back the drum, ensure that everything snaps into place.
  • Close the top cover.
  • Restart your printer.
I most certainly hope this helps.
Thank you for using FixYa.
Mar 25, 2011 | Canon PC-940 Black and White Copier
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Error message stats 'pull out trays clear jam, close cover A. but can't find any paper in machine and cover a is closed
a very usual problem steve. try removing power to the printer and let it stay idle without power for abt 20-30 minutes and then try again.this should clear the error message from the memory.
Feb 04, 2010 | OKI B6200 Laser Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
My OKI B6300 printer have problem: "pull out all trays, clear jam" & "clear jam & close cover A" These 2 screens keep alternating. I am familiar with saying, "clear jam & close cover A" because I had...
There are several reasons why this error keeps coming up, and seeing the date I will assume that you fixed it. But for those that are looking for the solution:
Sometimes it is caused by the feed rollers not picking up the paper - remove the trays and replace the rollers ($30 kit) both in the tray and in the printer.
Sometimes it is caused by a small piece of paper jammed in works somewhere. Remove all trays, turn it on its side and use a flashlight to look around. It really doesn't take much to mess it up.
Take a look at the tray roller and make sure it is spring loaded. If the spring comes out or the retarder breaks tis will cause misfeeds as well.
Feb 12, 2009 | OKI B6300n Printer
Okidata-B6200-
Check the reg sensor for dirt etc and paper setting is correct in the paper tray
Sep 24, 2008 | OKI B6200 Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
OKI B6200 Laser Printer Logo
1,268 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
