Question about Tascam CC-222mkIII CD Player / Recorder
Record single track instead of multiple track
How to record single track instead of multiple tracks on cd
  • 41 Answers
Turn off Atrack (auto track) and sync record.
Posted on Oct 06, 2009
  • Linus_007 Oct 06, 2009
    Turn off Autotrack and Turn off Sync Record. This will give you one track until you press thet rack or record or pause button. At this point in time you will start a new track.
When I try to burn recorded track, shows a message CD full when I check remaiing spcace, it shows full available
i think the maximum capacity of a CD is between 750MB to 850MB . since the error message is CD full better check the amount / volume of data to be transferred to your CD .
Aug 27, 2014 | Cameras
TDK DA-5700 records from cassette to cd-R but nothing happens when I press FINALIZE and then PLAY (ENTER). Why?
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
Feb 09, 2012 | Audio Players & Recorders
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
I have recorded single track on to rewritable disc. on windows media player . it has been finalised will not allow me to record another track to disc. How do i do this? many thanks ALEX
If you are using CD +/- R cds or DVD +/-, you can only write to them once. Once something has been written to the disk no mater how small, that is the only time it will write. In order to add multiple tracks to a disk you will have to create a play list that will fit on the disk then burn the entire list all at once. The only disks that allow for multiple write capabilities are CDRW +/- or DVDRW +/-. When using those types of disks, make sure you do not overwrite the tracks that are already installed on the disks.
Jan 02, 2010 | Computers & Internet
Burning using Tape2PC
if you are using itunes and you have a cd burner on the laptop...you just pick approx 10-15 tracks from itunes (it also depends on how big the mp3/4 tracks are) place your correct (cd +/-, 16x or 8x) type of blank cd in laptop and burn ...
Sep 25, 2009 | ION Audio TAPE2PC Single Cassette Deck
How do get multiple tracks when djing
press the next botton on the recorder every time u switch songs djin".
Dec 28, 2008 | Philips CDR775 2-Disc CD Recorder
Printer loads multiple pages
You may be using a cheap (thin) paper weight. Try a thicker gauge paper. Could be dirt or dust in the feeder track. Try vacumming it out and try again.
Dec 12, 2008 | HP PSC 1401 All-In-One Printer
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
My 2006 Camry's CD player jumps track
You have the RANDOM feature engaged. Look at the player and push the button under the word "RAND" off. The RAND is just that: random tracks.
Jul 25, 2008 | 2006 Toyota Camry
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Tascam CC-222mkIII CD Player / Recorder Logo
96 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
