Question about HP Office Equipment & Supplies
My HP Laserjet 2430dn makes a grinding noise after power on.
HP Laserjet 2430dn makes a grinding noise after power on, then displays error message 13.0.0 paper jam. Removed toner cartridge and paper tray 2, but negative for any paper jam. Checked duplexer area, again no paper jam found. Any suggestions on resolving this delimma is greatly appreciated. Thanks in advance.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Posted on Jan 21, 2011
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
Feb 03, 2017 | HP Laserjet M1522nf All-in-one Laser...
Hi can u help me my 2840 laserjet paint error 54.2 ..rotating to mageta
Display Description The device has experienced an internal hardware error.
Carousel rotation error Remedy Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
Replace the carousel drive motor. If the error persists, replace the DC controller. If the error still persists, inspect or replace the engaging detection flag.
Apr 03, 2015 | HP LaserJet 2840 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Making noise then displaying error asking to turn printer off
Just we cant judge reading the sound if we hear the sound we can say the fault, any how check fuser assembly seated properly or not? open side doors then observe where you are getting the sound..
Jan 30, 2012 | HP LaserJet 4600 Printer
Hello! I have got a 6 year old HP laserjet 3330 all in one laserjet printer.As soon as I switch it on, it makes a grinding noise. I think it comes from the a4 sheet feeder area. I tried lubricating...
I don't think the toner cartridge is amiss here. I think that on hp printers that are older, such as yours, the rubber feed rollers shrink and cause feed problems, over time.
Feb 09, 2011 | HP LaserJet 3330 All-In-One Printer
The printer makes a grinding noise I took the right hand side plate off. There is nothing jammed inside.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 08, 2010 | HP LaserJet 1020 Printer
HP Laserjet 2430dn printer 50.6 Fuser Error
It is a fuser problem; you don't say, but I suspect that you replaced the original fuser with a re-manufactured fuser. I have seen this problem before; return the replacement fuser to where you bought it and tell them it is showing a 50.6 fuser error. BTW, here is a link to a PDF file that may help you with your troubleshooting in the future.
http://www.partshere.com/Models/Q5964A/LJ2400Troubleshooterrors.pdf
Mar 05, 2010 | HP LaserJet 2430 Printer
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Apr 03, 2008 | HP LaserJet 9500n Printer
1,271 people viewed this question
Seeker5211
Seeker5211
