Question about Rangemaster 110 (Gas) Kitchen Range
Rangemaster gas grill - little or no gas pressure
Rangemaster 110 now 10 years old. Over time the pressure of the flame form the grill has got weaker to a point that it is now not sufficient to keep alight
  • 1 more comment
  • Anonymous Feb 26, 2009
    How do I remover the burner from the grill, there is not much room in there.
  • markmoloney May 25, 2009
    Right at this stage I have removed the top and sides off the unit and exhausted all angles including, cleaning the burner, the gas valve, the gas venturi, the igniter wire and checked the actual grill knob is working. Still no success. What the hell is the solution.
    Thanks in advance
  • David Shaub May 11, 2010
    Check for tar buildup in the gas orifices. Turn off gas at main, remove the burners and look for tar where the gas comes out of the body of the stove and enters the burners. A straight pin or a very thin sewing needle will work. Don't use anything as large as a small paperclip. It's too big and will change the amount of gas flowing in to a possibly unsafe lefel.
  • 188 Answers
You can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Posted on Mar 26, 2009
Have just had a brand new Rangemaster 110 installed for less than a week. Initially everything worked fine, then, Christmas day the gas stopped working completley on all hobs. All cylinders were full but no hobs would produce gas when knobs tured.
I have tried the rangemater help lines but they are helpfully off until the 29th.
Not impressed as there appears to be no obvious answer, can anyone hel;p?
Posted on Dec 26, 2009
One side of the grill gets hotter than the other.
Is this grill new? How many burners are on this grill? Typically if there is a pressure problem, the farthest burner from the regulator suffers. Looking at the photo of the grill, the tank and regulator are on the right, which would make the left side burner weaker. The flames can be even all around each burner, but if the burner on the right has slightly taller flames than on the left, even increasing the pressure won't "even" it out, it would just make both bigger. It could be just the nature of the beast. If it was feasible and the left and right burner were identical, it would be interesting to see if switching the burners would make any difference. Check to make sure each burner's air shutter adjustment is the same and adjust each for the bluest flame possible. Look for spiderwebs, bugs, or rust debris and blow out with air compressor, if possible. Let us know if you need more assistance. Good luck!
May 18, 2010 | Weber Genesis Silver B Grill
My grill lights, but won't really heat up. I
try cleaning the burner and the orffice , check reg is giving right pressure
May 10, 2010 | Thermos Gas Grill 4617222
Low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Apr 27, 2010 | Weber Genesis Silver B Grill
Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Feb 19, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Rangemaster 110 (Gas) Kitchen Range Logo
1,607 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
