Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
Galazy 2547 does anyone know how to turn up (mod) and what is the small plate that has three claps on it inside this radio at the back
  • daylonrrober
    daylonrrober Mar 01, 2009
    three clamps lol no claps
  • daylonrrober
    daylonrrober Mar 14, 2009
    i had no clue what it was .thanks i am taking it to clays radio shop to let them work on it to set freq it is showing 27185 am 27184lsb and 27189 usb cant clear up anyone
  • 40 Answers
The board pushed into the clamps toward the back is the voltage to the finals do not play aroud it or you will be buying another radio just a warning. the modulation adjustment is made to vr 16 for am modulation and vr 13 for ssb thats lsb or usb do not turn any other
variabe resisters unless you want to spend the money to have it realigned to the tune of about $ 75.00-100.00 because it is a sidband radio.
Posted on Mar 13, 2009
  • james morgan Mar 15, 2009
    clays is a good choice he does realy good work
Water does not heat
depends if it is an older model .and yea hard water deposits. can slow down or plug up the tube.. if it is a new one , machine lights up etc ,but no boiling water ? then the thermal fuse inside under the plate or by the aluminum tube clap on set is burnt out..usually an 8 or 10 amperage small as a aspirin pill about $ 8.00 at radio shack ..we like the resettable instead ..but must drill a small hole in plastic body...
Mar 18, 2014 | Cuisinart Coffee Makers & Espresso...
Galaxy 2547 off frequency
1 one thousandth of a number and you are worried. now if it said 27.18350 instead of 27.1850 then you would be off frequency.but for that little bit its not even a problem
Mar 06, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
I WANT TO BUY A GALAXY 2547 CB RADIO. I FOUND ONE AND IT SAYS EXPORT USE ONLY . WHAT DOES IT MEAN, CAN I USE IT. THANKS
Normally, this radio will only work on CB frequencies. I suspect the radio has been modified to get channels below and above the regular 40. If so, the radio is no longer type-accepted by FCC. It is unlikely you would get into trouble using the radio.
....Don at NTCB, Inc.
Jun 25, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
I need to clip claifire to slide only when buten it pushed. how do i do it
You really do not want to do the clarifier mods... then when your on ssb you will be off frequency to a person that has a factory radio. Just not good operating procedure...
Feb 23, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Need bulb replacement for DX 2547 meter for swr,mod,power and etc. Thanks
You will more than likely need to get the OEM part for this as I do not know of an after market. There is only one place in the country that sells them. Maycomm Communications www.maycomcomm.com They are the only one in the US that deals in new OEM Galaxy radio parts. That is where I go for parts for Galaxy radios I cannot find. You can also call some random CB shops to see if the have that meter from a parts radio they have laying around but for me, if I open a radio, I use new parts only. Good luck. Maycomm will fix you up.
Feb 16, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
90900237 is the serial number on my galaxy 2547
According to a post in a recent forum it was made in September of 2009. I am not sure this info is accurate but it was published as such.
Jun 12, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Radio Dies with Noise
sell it now! Ebay would be a good place
Jan 30, 2009 | Tivoli Model Three Clock Radio
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
301 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
