Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Pixels scatter around tv when turned on
Was watching tv and the screen flashed and little different colored pixels started popping up all through out the screen. how can i fix the problemb?
  • tmjkm Mar 07, 2009
    When I turn on my Zenith 50 in HD Plasma TV, I have little colored pixels flashing all over the screen. It can be seen more on black images during a program.
Emerson TV turned off and won't come back on
Main power supply regulator board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 21, 2017 | Emerson Televison & Video
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
When I turn the projector on I get scattered bright white pixels showing up on the screen with no color. What causes this.
Hello!
Bad news: the problem is the light engine! most expensive part of the projector. Due to high temperature inside and extended usage with poor ventilation, plastic filters inside the light engine start melting and picture gets "spotty". Next, the color matrix quits and one of primary colors is missing. In any case, light engine is "goner". It's very big job to replace it. I would surrender to repair facility in your place. Or, if you can get replacement projector for a good price, just do that. Your projectors repair bill might be $500+,or more. due to high cost of light engine.
Good luck,
thanks,
Alex.
Dec 21, 2011 | Panasonic ET-LAC735 Multimedia Projector
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Black strip left side of the screen
Apr 30, 2010 | Samsung HL-R7178W 71" HDTV
White dots on screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screen. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 27, 2010 | Samsung HLS4266 TV
I have a samsung DLP TV, model HLN5065WX. When I plug it in after a few seconds both the lamp, and temp lights flash on the front. It did have just the lamp light flashing and it would have horizontal...
Apr 02, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung plasma PS42D5S
You need to adjust the panel voltages, adjust the VS voltage to around 186 volts, if that doesn't change it then adjust the V-Scan voltage down, turn the unit on and apply a video source to it, and while adjusting the voltages look at the screen and you should be abe to watch the video noise fade out.
Dec 14, 2006 | Samsung PS42P2S 42 in. Plasma Television
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
