Question about Compaq Presario M2000 Notebook
I have a problem with my compaq presario M2000.three weeks back in my screen 3 lines appeared and in one more weeks time two more lines. now i have 6 line appearing on my screen. it looks like the no. of lines appearing on my laptop screen is increasing. i want to know the problem why so it is occuring and if i have to fix it on how much it is going to cost me
  • responsecomp May 11, 2010
    if you plug it into a monitor does the same fault occur?
    Responsecomp
    Champion:
  • 203 Answers
Hi it look like your laptop was droped down, can you check the conection inside the screen ?that is hapen wen the conection of the screen is not ok.open the screen and check the conection on the back of the screen,take care to not damage the small cell on the screen cose if you do you will have more line on screen.that is the way i fixed that matter on a few laptop's.
Posted on Feb 26, 2009
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
Repair manual for compaq presario M2000
Free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Computers & Internet
Very thin vertical red line just appeared on my monitor. It is about 5-6 inches from left side.
LCD is starting to go bad. Anytime lines start appearing randomly or constantly, the pixels are going bad so the screen needs replacing.
Nov 30, 2009 | Compaq Presario M2000 Notebook
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Vertical lines appearing on my laptop screen
...not good. Generally means your screen is on it's way out.
Jun 22, 2009 | Compaq Presario M2000 Notebook
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Have three vertical lines on my laptop Acer Aspire 3000
This problem is possibly due to blown diodes in the LCD panel.
Apr 19, 2009 | Compaq Presario M2000 Notebook
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Two vertical lines on my compaq presario (M2000) laptop
Well, since the line disappear when the screen saver comes on, I"m led to believe that all the hardware side of the equation is OK. To put it simply, if there was a malfunction in the video (chances are) it would affect that too.
I would update (most likely available as nobody usually does this) the firmware for your video card. So identify the card EXACTLY, from documentation, or from the build list on the manuf. website, goto the manufacturer, say, ATI, and find the firmware there, where you will also find instructions to install it.
Then, just to be sure, I would update the video driver for Windows, in a similar manner to the instructions above.
If, despite all the above you still have a problem, then its time to get the computer serviced.
Good luck,
Erik.
May 16, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
