Question about Galaxy G14-AT Popcorn Maker
Corn not properly popped.wastage is more than optimum level.
  • 109 Answers
Are you using fresh popcorn? Old seed will dry out and do this. Is your machine maintaining the proper temperature?
Posted on Mar 29, 2009
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
I lost the instructios for the amount of kernals to put in and if put oil in the well
If you have no idea what brand or model number you have and the kettle is heating properly you can figure it out pretty close just by timing the popping cycle. The ratio is 3 parts corn 1 part oil. so a 12 oz kettle would be 12oz of corn (1-1/2 cups ) to 4 oz of oil. A good popping cycle takes about 3 1/2 min from the time you add the corn and oil to dump time. you can make ajustments for the results you get.
Dec 26, 2015 | Kitchen Appliances - Others
Static noise when headphones are plugged in and there is no inputs or outputs
Unless the levels are turned down I would expect that. It probably is what is called pop-corn noise. Turn the levels down it should disappear.
Apr 14, 2014 | Behringer XENYX 5-Input Mixer 302USB
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
I have a Star model 89, manufactured in about 1986. Its a 14 oz kettle, and everything works, however the kettle will not pop the corn. The kettle is hot to the touch from the outside, but will not pop...
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Nov 04, 2010 | Star 39 JetStar Popcorn Maker
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
How much oil or corn do you use in the Back to Basics Pop Corn Popper for the stove
unless you have the instruction manual, only trial-and-error will tell you. Start with 2 tablespoons of oil and 1/2 cup of corn kernals. If there is oil left after the corn is popped, decrease the amount of oil by a teaspoon. If the popped corn is burned, increase the oil by a teaspoon. As for the corn, if the pot is full when the popping is done, 1/2 cup is the right amount. If the popped corn over flows, 1/2 cup is too much. Vary the oil and corn until you get it right. Good luck! I love popcorn, so I wish you the best.
Feb 02, 2010 | Back to Basics 6112304 Popcorn Maker
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
Directions for presto carmel cormer model #0500001
I have the directions for this; send me your address and I'll mail you a copy or I could probably just I have a Presto Caramel Corn'r. These are the directions:
You need a large mixing spoon, wax paper and the following ingredients:
2 T cooking oil
¼ c popcorn
¼ c butter or margarine
½ c brown sugar
2 T light corn syrup
¼ t salt
1/8 t soda
Then follow these steps
1) Pour cooking oil and popcorn into the unit base. Place cover on base. Plug cord into base and then into wall outlet. The signal light will glow when unit is heating. When popping is completed, the signal light will go out indicating that the heat has shut off automatically. Unplug the cord from the wall outlet. Tip unit upside down so popped corn falls into cover. Set cover with popped corn aside. You may want to use a paper towel to remove excess oil and unpopped corn or hulls from the base before making caramel sauce. NOTE: I pop corn for all the batches I intend to make first then do the next steps because you don’t have to clean it each time to make a new batch.
2) To make caramel sauce, combine butter, brown sugar, corn syrup and salt in the base. Plug into wall outlet. Heat mixture stirring constantly until butter is melted and sugar is dissolved. Continue cooking, stirring occasionally for three minutes. Unplug cord from outlet and unit.
3) Place the mixing band on the base. Add baking soda and stir until mixture is evenly colored, light and foamy. Add popped corn, stirring to evenly coat with caramel sauce. Remove mixing band. Pour caramel coated corn onto wax paper and separate kernels. Let stand a few minutes before serving. Wash unit before popping more corn.
Aug 04, 2008 | Kitchen Appliances - Others
Microwave will not function properly.
The cavity thermal fuse may have failed. It is located on the top of the cavity.
Jun 13, 2008 | Microwave Ovens
Galaxy G14-AT Popcorn Maker Logo
88 people viewed this question
Top Galaxy Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Galaxy Kitchen Appliances - Other Expert? Answer questions, earn points and help others
