Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
My SimpleTech Signature Mini will not format to work with my mac
I got a SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive, and unfortunately, my computer cannot format it to run for Mac use. I followed the steps on the quick start guide, but when I get to the Disk Utilities page, the 'drop down menu' that it lists (which I assume is under the Erase option) will not allow me to alter the hard drive in any way, and I don't see any other option available to me. I checked the information and currently it says 'unwritable'.
I already downloaded the Fabrik backup program directly from the hard drive, but I don't think that that is the problem. If anybody knows how to fix this problem so I can actually save/transfer files directly onto my external hard drive, I'd appreciate it very much.
  • k_nicholson Apr 09, 2009
    Same thing is happening for me. I select "MacOS X Extended" and hit erase, but it doesn't work.
SOURCE: Simpletech 320 GB
how do you open it?
Posted on Mar 05, 2008
WeListen2You
  • 538 Answers
SOURCE: Not detecting
hmmm..what operating system you using..
Posted on Oct 13, 2008
SOURCE: My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Posted on Mar 23, 2009
SOURCE: Fabrik simpletech 160GB external HD
Dear,
I think this is warrenty period and you should visit your nearest service center.
Regards,
Rakesh Kumar
Posted on Apr 01, 2009
popemohamed
  • 31 Answers
SOURCE: mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Posted on Jun 16, 2009
My 300GB simple drive external hard drive shows up on my mac, and all the files are there, but it won't let me write to it any more. It is nowhere near full, and I have written to it before. I can copy...
Blah, stupid question about this folder, of course you can't.
If you have such possibility. The easiest sollution and almost guarantee it will work.
Copy all files from this ext HDD on your local pc and just format this HDD using windows formatting tool (right click on this HDD in my computer -> Format...)
pick NTFS of course
Cheers,
Mike
Leave rate if I helped you, thanks!!
May 08, 2010 | SimpleTech Signature Mini 160GB External...
My simpletech drive is showing on my iMac but I am unable to write any files to it. It says I can only "read" but it does not alow me to change the access.
These things come formatted for PCs--you have to go into Utilities on your mac (in hard drive click on Applications, Utilities folder, then Disk Utility, then click on the simpletech (that has the gb next to it), click on the drop down to change the format (MS-DOS if you want to read on both PCs and MAC, but MAC-OS for just Macs) re-name it on the drop down below that, then click on erase and then it's re-formatted.
Jan 17, 2010 | SimpleTech Signature Mini 160GB External...
I plug my Simpletech Signature Mini hard drive in but than I don't know what to do from there.
When you plug the drive in, Windows should recognize it and make it immediately available for your use.
To confirm this, click Start then Computer and it should show up as a device with removable storage. If you click on the Signature drive, you will see the contents of the drive and you can use it just as ou would your "C:" drive.
Sep 05, 2009 | SimpleTech Signature Mini 160GB External...
Where can I find a Mac driver from a Simpletech 250gb Marshmallow It has been formatted on a PC. I now want to reformat it and use it on my Powerbook G4 OS 10.4.7
You shouldn't need a special driver, but you do need to plug in the usb y cable to 2 usb ports. Normally 1 usb port doesn't supply enough power to make external USB drives go. That is why I prefer firewire, it supplies much more power at higher sustained rates. Once the drive is going just open the Disk Utility and format for your needs. If you need to share files with a PC, partition as MS-DOS (FAT). If you are sharing with a mac or not using the drive on other computers, format as extended with journaling.
Jun 20, 2009 | SimpleTech Signature Mini 250GB External...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Dear,
Regards,
Rakesh Kumar
Mar 31, 2009 | SimpleTech Signature Mini 160GB External...
Simple tech signature mini 169 GB
how do I reset my format from a Windows to a MAC
Oct 25, 2008 | SimpleTech Signature Mini 160GB External...
Not detecting
Oct 13, 2008 | SimpleTech Signature Mini 160GB External...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
590 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
