Question about Microsoft Windows XP Professional for PC
I Can change my XP theme?
RAM G.B.
Service Pack 3
Hard Disk 160 G.B.
  • 4 Answers
Use the display control panel applet (right click on the desktop->click properties->themes tab & select the one you want... you can also download those avail for free on microsoft website too, if your OS is original..
Posted on Feb 26, 2009
  • 3 Answers
Just used the tune-up utilities or the tweak xp
I need to reinstall windows xp home edition i have the product code but no disk
I have used full install/ disk from other brands of computers (or other dell model numbers)to reinstall operation system (must be winxphome, dont worry about service pack, you can update). If you use any dell reinstallation cd, most likely you will not have to enter your key. If you use any other computer brand, or borrow someones xphome full install disk (not upgrade), then you will need to enter your key. Only problem of using for example emachine full install disk is that is will have emachine themes. Also you will likely need to down load other drivers. You are not lemited to to using reinstall cd for your model number. Good luck
Aug 28, 2012 | Microsoft Windows XP Home Edition Service...
Windows XP 32 bit setup disk
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
hope it helps
May 16, 2012 | Microsoft Computers & Internet
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Computers & Internet
What are the required package for microsoft security essentials for my xp
The following are the system requirements for Microsoft Security Essentials
Operating System: Genuine Windows XP Service Pack 3 (SP3); Windows Vista (Gold, Service Pack 1, or Service Pack 2); Windows 7*
  • For Windows XP, a PC with a CPU clock speed of 500 MHz or higher, and 256 MB RAM or higher.
  • For Windows Vista and Windows 7, a PC with a CPU clock speed of 1.0 GHz or higher, and 1 GB RAM or higher.
  • VGA display of 800 × 600 or higher.
  • 200 MB of available hard disk space.
  • An Internet connection is required for installation and to download the latest virus and spyware definitions for Microsoft Security Essentials.
  • Internet Browser:
    • Windows Internet Explorer 6.0 or later.
    • Mozilla Firefox 2.0 or later.
  • Microsoft Security Essentials also supports Windows XP Mode in Windows 7. For more information see the system requirements for Windows XP Mode in Windows 7.
*Your PC must run genuine Windows to install Microsoft Security Essentials.
http://www.microsoft.com/en-us/security_essentials/default.aspx
Jun 13, 2011 | Microsoft Computers & Internet
I upgraded my hp pavilion zd8000 to 2GB of ram. When I try to load windows XP, I get a can not format disk error. I removed 1 GB of memory and added 250 K in it?s place and everything installs and runs OK....
what service pack are you running ? if you have service pack 3 installed you can not reinstall the OS period , you'll have
to remove the service pack 3 and go back to service pack 2
ram and the HDD don't have any connection with the OS
you can try switching out the ram to another computer for
testing and for checking the DIMM slots on your computer
if its a notebook there will be only 2 slots if its a PC you may
have 4 check your manual for 1234 configuration they never
go as 1234 its usually 1324 , windows XP 32 bit edition will only
hold 3072 MB of Ram while the 64 bit edition will hold up to 8
gigabytes .
Mar 11, 2010 | HP PAVILION ZD8000 SEREIS 100GB (4200...
Recommendation of the dreamweaver cs4
Hai,
Windows Dreamweaver System Requirements
In order to run Dreamweaver CS4 on the Windows platform, you need the following minimum system requirements:
* 1GHz or faster processor
* Microsoft® Windows® XP with Service Pack 2 (Service Pack 3 recommended) or Windows Vista® Home Premium, Business, Ultimate, or Enterprise with Service Pack 1 (certified for 32-bit Windows XP and Windows Vista)
* 512MB of RAM
* 1GB of available hard-disk space for installation; additional free space required during installation (cannot install on flash-based storage devices)
* 1,280x800 display with 16-bit video card
* DVD-ROM drive
* Broadband Internet connection required for online services
Macintosh Dreamweaver System Requirements
In order to run Dreamweaver CS4 on a Macintosh, you need the following minimum system requirements:
* PowerPC® G5 or multicore Intel® processor
* Mac OS X v10.4.11–10.5.4
* 512MB of RAM
* 1.8GB of available hard-disk space for installation; additional free space required during installation (cannot install on a volume that uses a case-sensitive file system or on flash-based storage devices)
* DVD-ROM drive
Hope it Helped!
Aug 26, 2009 | Adobe Dreamweaver CS4 for Mac
My pc is extremely slow, I have even formatted and instal a new version of Windows Xp service pack 2 to my PC pentium-3 with 256 RAM but there is still no change. Need some one to help me out.
slow pc is the cause of many problems.
1=firstly,use disk cleanup.
2=secondly,regularly defragment your hard disk.
3=thirdly,try to switch over to pentium 4 3.0 Ghz or intel core 2 duo.
4=at last,change your motherboard to ddr2 Ram supporting Board.
Dec 30, 2008 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Exactly same slow working especially slow boot up and shut down problem with Cpmpaq EVO N610c.I reformatted twice and installed windows xp professional but still same proble.i have 30 gb hard disk with...
Hi there
Don't bother with service pack 3, it will only slow the pc down even more, what you need is a memory upgrade so the machine can perform well, also a better hard drive would be a good idea
kind regards and please don't forget to rate us
Dec 09, 2008 | Microsoft Windows XP Professional With...
Use of vista theme at windows xp
u need luna 2 tools bars black nice blue best for xp
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
