Question about JVC Everio GZ-MC200 Camcorder
New sd memory card 8 gb keep formating
When i install a new SD 8GB memory card the camera keep formating it but doesnt finish it.
is it a fault with camera or it just doesnt support 8gb sd card.I have the same problem. I really hope someone can help us out on this.
  • Curtis Wilson Feb 26, 2009
    I will try formating it on my computer later today. I have not tried any other SD card than the 8gb.
    Is it possible to get a larger microdrive? Maybe like a 16gb or 32gb? The 4gb microdrive is basically worthless since it will only shoot about 45 minutes of video.
    Thanks!
  • Curtis Wilson Feb 27, 2009
    This information has been fantastic. I really appreciate the quick response.
  • JVC Master
  • 13,433 Answers
Try formating the card on your computer and see if the card works, if it does try it again on the camera, if it still doesn't work properly on the camera, try formating it on a diffrent file system with the computer.
If the card still doesn't work It might be too big for the camera? unlikely?
Posted on Feb 26, 2009
  • 3 more comments
  • Ekse Feb 26, 2009
    Heres how to format the card on your computer,
    plug it in and open my computer, find the card from the list then right click and select format
    In the format window try diffrent file systems, my camera uses a FAT system, so try formating the card with FAT, FAT32 and NTFS if available. and between formats test it on the camera to see if theres any improvement.
    If the card works perfectly on your computer, then the issue is between the card and the camcorder, possibly too big? but thats unlikely I'll have to check. Or it might be the wrong type.
    does any card wrong on the camcorder? Also please use the add a comment feature to respond to me instead of reposting, which will reject my assistance.
    Thanks,
    Ekse
  • Ekse Feb 26, 2009
    Do you have a 1GB, 2GB or 4GB card to test on the player? 1GB is definitely supported. Not completely sure about 2gb or 4gb. have you tried those? the 8GB sd card is bigger than the internal hard drive. so it very well might not be supported.
  • Ekse Feb 26, 2009
    I will check and get back to you soon.
  • Ekse Feb 26, 2009
    A microdrive or a CF+ TYPE II card is supported Atleast up to 8GB. The card needs to be a microdrive or a CF+ TYPE II card. 8GB cards are available and work with the camcorder.
    I would suggest going to a camera shop and testing out a 16GB or 32GB card before purchase and see if it functions (if the store allows you)
    I'll check with JVC about the 16GB and 32GB sizes and get back to you.
  • Ekse Feb 26, 2009
    I've got a reply from JVC support:
    Thank you for contacting JVC Customer Care. I am Jose, your email care specialist. We value you as a JVC customer and appreciate the opportunity to be of assistance.
    I understand that you are inquiring some specifications for your Everio camcorder. We have checked our information,but are unsure if this camcorder will work on Compact Flash cards higher than 4GB since that was the max size made during 2004. We would suggest purchasing a higher size card and inserting it to see if it is able to be picked up by the cam.
    If we can be of further assistance, please let us know at customerrelations@jvc.com.
    Sincerely,
    Jose
    JVC Customer Care Center
    Even JVC is unsure.
    So try it out at a store and see if it works or not.
    Let me know if you need anything else.
    Thanks,
    Ekse
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
My SD card will not format
Get an SD card. Your 8GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work with your camera. You need to use an SD card, 2GB and smaller.
Jul 19, 2012 | Kodak EasyShare CX7530 Digital Camera
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
When I put in my SD 8 GB memory card, busy signal
An 8GB SD card will actually be a SDHC card, the HC means High Capacity. Your camera is only designed for regular SD cards up to a maximum capacity of 2GB; it's incompatible with SDHC at the basic hardware level and so cannot format the card.
You only have one solution: fit an SD card which does not exceed 2GB. Note that the specification for regular SD cards goes up to 4GB, but very few standard SD devices were ever designed or tested for compatibility with them. The few regular SD cameras which can use them mostly can only do so after a firmware update and even then will operate very slowly compared to when using a 2GB card. There has never been a firmware update to enable your camera to use 4GB SD cards.
I hope that you have found my posting to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 01, 2009 | Jazz JDC87 Digital Camera
The camera doesn't accept new memory card put into the camera
Sorry that this answer is far too late to be of use to you, but it may help others searching for advice with the same fault. I only stumbled across your unanswered question by accident.
8GB is an SDHC card. Your camera was designed to use the earlier SD cards instead with a maximum 1GB capacity.
Dec 07, 2008 | Kodak EasyShare C533 Digital Camera
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 31, 2008 | JVC Everio GZ-MC200 Camcorder
    JVC Everio GZ-MC200 Camcorder Logo
    103 people viewed this question
    Top JVC Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
