Question about Estate TGDS840JQ Gas Dryer
The dryer 'On/Off' switch not working. Dryer does not turn on.
The 'On/Off' switch is punched in, but the dryer will not work. We have checked breakers, etc., and power seems to be available to it, but trying to click this switch; we cannot get it to basically 'Go On'.
Please HELP - anyone. I need to use the dryer, and hate to call a repairman when it could be something simple, and save us money.
Thank You!
  • 89 Answers
Sounds like the internal parts of the switch are damaged and not allowing the required circuit to be closed. There are many kinds of dryers and switches. If you can pull the switch out and observe the wiring on the back, it may be possible to "jump" the wires. Use extreme caution not to electricute yourself. Basically if it's just a push on to start dryer, all that needs to be done is the two wires in the switch to contact each other for a second. DO NOT TOUCH THE ELECTRICAL CONNECTORS. Hold the insulated wire in each hand and touch together briefly. This should start the dryer. DO NOT LEAVE THE WIRES EXPOSED. Put back onto swith being careful not to touch the metal connectors.
Posted on Feb 26, 2009
My dryer turns on but wont run
There are several bimetallic heat sensor switches in a dryer. Check them first, then the continuity of the door switch, then the control unit ( I usually get mine rebuilt), finally the motor as a last resort.
Feb 12, 2014 | KitchenAid KGHS01PMT Electric Dryer
I have a 2 year old Maytag Neptune gas dryer. I leaned up against the rotary selection knob for about 20 seconds to get to something behind the dryer. The dryer has not worked since. Turning the knob no...
If the power is there, you will want to check the door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty. Make sure that the control settings are appropriate, and that any buttons are fully depressed. Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
The door or lid switch performs two main functions. When the dryer door is open, it keeps the dryer from starting, and turns on the light. If the door switch is faulty, your dryer won't work, and you'll need to replace the switch. The door switch is located inside of your dryer's main housing right by the door frame. You'll probably need to access this switch through the top or front of your dryer.
There may also be a problem with the start switch. Test and replace if it is faulty.
Many dryers use what's called a thermal fuse. This is often mounted within the exhaust duct in the back panel. This fuse is about an inch long, and is usually found within a white plastic housing. Your dryer will not operate if this fuse is defective. You can test this fuse, and if faulty, replace it.
Most fuses have a thin wire that conducts electricity. When fuses blow, it means the wire is broken, they have no continuity and no power will flow through it. When this happens to the thermal fuse, your dryer either doesn't work at all, or it stops heating. Give your vent and heating system a visual check before you replace this fuse.
You will also want to test each thermostat to determine if any one is faulty. A bad thermostat may prevent your dryer from working at all.
Aug 07, 2008 | Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Dryer stopped heating, still tumbles, also the push to start switch has to be held down now for it to work at all. checked voltage (good) checked cotinuity of all parts and all were good except the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 09, 2011 | Kenmore 63942 Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Dryer is not working. You cannot hear engine working when machine is turned on. Dryer is not starting and I do not her the motor when the dryer is set to work. I have checked cord and fuse box - ne
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer not heating, Interimittent Problem -------------------------------------------------------------------------------- Having an intermittent problem. The dryer turns on, drum spins, but you have no...
Have you tried to bypass the hi limit switch or the thermal switch. It will work. If it works for a few times, then you will know the switch is bad. I did this on a friend's one time and it solved it. Only cost about 15 bucks. Godd luck and let me know how it turns out.
Jan 13, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Dryer will not turn on
Door switch
Thermal fuse
Wiring
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Dec 15, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Estate TGDS840JQ Gas Dryer Logo
167 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
