Question about HP Compaq Presario SR2150NX PC Desktop
Blue screen error message, computer will not boot up
I have a persario sr 2013 media edition 2005 PC. I started having problems with it were there was a black screen with the potions of using safe mode, safe mode with networking,last known configuration used, or normal start as if you press the F8 key while starting the computer. I took it circuit city so they could check it out and do a complete sevice work on it. After getting it back, I started having more problems on it were when you go online and look up something the same site would pop up again 3 seconds after the first time it came up. I took it back to circuit city and they could not find out why it was doing that. I started having more problems were a blue screen popped up saying a problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you have seen this stop error screen, restart your computer. If this screen appears again follow these steps:
Check to be sure you have adequate disk space. If a driver is identified in the stop message, diable the driver orcheck with the manufacture for drive updates (did that and did not work). Try changing video adapter. Check check with your hardware vendor for any BIOS updates. Disable BIOS memory option such as caching or shadowing if you need to use safe mode to remove or disable componets. Restart your computer and press F* to select advanced startup options, and then select safe mode. I tried to follow these directions but the computer would not do anything and kept booting up back to the same page. I did a F1 to check the channels and ran smart short self test and a extended self test and everything passed. I tried to do a system recovery through the computer and the recovery disks (new ones) and that didn't work. I even installed a new hard drive and tried to install the operating systems with the recovery disks and the same blue screen came up after it ran through like it was doing a system recover from the computer. Need help.
  • gilbert banate
    gilbert banate May 11, 2010
    go to the bios setup, set to default format? f blue screen again?! change your ram or the memory card with a new ones?!!
  • 89 Answers
Check your ram. You may have a bad memory module. If you reinstalled your operating system on a different hard drive, then it sounds like it may be your memory. Turn the computer off, remove and reinsert the memory. Turn computer back on. If this does not work. Remove on of the memory modules and see how that works. Then if that doesn't work, remove the other memory module and plug the other one back in. Be sure the memory is seated properly. Always have the power off when doing this.
Posted on Feb 26, 2009
I start up my computer and i get a black screen that says "NTLDR is missing Press Ctrl+Alt+Del to restart" at the startup screen pressing f10 doesn't bring up system recovery and I don't have...
what is the model of your computer,? if the recovery software is in a hidden partition there must be a way to access it from boot, otherwise, you will have to buy a windows disk and reinstall windows.
Feb 05, 2011 | Microsoft Windows XP Media Center Edition...
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even...
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
Jul 08, 2010 | Microsoft Windows XP Media Center Edition...
Windows xp media center edition 2005 low memory error when installing blue screen & install fails
Try the following:
Click Start-> Run
Type msconfig and press Enter
Click on the Startup tab
Click Disable All
Click Services tab
Click on the checkbox Hide all Microsoft services
Click Disable All
Click Apply and Close
Restart the computer.
When it starts again, you will get a notification about using the system configuration utility.
Click the checkbox for Do not show this again
Click Ok
Now try to install your application and let me know
Mar 10, 2010 | Microsoft Windows XP Media Center Edition...
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Error message when starting up: <Windowsroot>\system 32\hal.dll. Please reinstall a copy of the above file.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD
command.
May 09, 2009 | Microsoft Windows XP Media Center Edition...
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
My screen shuts down automatically
hiiiiii friends
some virus on your pc .....remember you format it total driver........
Nov 10, 2008 | Microsoft Windows XP Media Center Edition...
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
HP Compaq Presario SR2150NX PC Desktop Logo
443 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
