Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water tube frozen
I own a kenmore side by side #51569101 frig the tube for the door icemaker has frozen up i think. i had a repairman come a couple of years ago and it was simple to access but icant remember how he done it all he did was stick the tube in hot water a couple of minutes ,I cant remember what part he took off to access this tube
  • 25 Answers
Try running the temp warmer in the freezer, Winter months the house temp. setting lower at night. Saving energy you can safely say leave the house temp alone. Sooooo You can leave the door light on for some heat. You can thaw it on those occasions by putting a space heater in front of the door. Or I believe they have a fix kit for hundreds of dollars installed.
Posted on Feb 26, 2009
My icemaker quit working. Water does not come in to fill the tray. Water source is turned on. In door water dispenser works fine. What should I do to troubleshoot? I don't hear the solenoid click in...
have you checked the inflow tube to see if it's iced up? if your icemaker isn't filling with water and your getting water in the dispenser your feeder tube is probably frozen
Apr 11, 2011 | Kenmore Side by Side Refrigerator
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Ice maker output very low volume
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Jan 05, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker whirlpool fridge
FIRST MAKE SURE IT'S ON,,THEN YOU NEED TO SEE IF YOU HAVE WATER TO THE WATER DISPENSER,IF YES CHECK THE TUBE GOING TO THE ICEMAKER,PULL TUBE OUT LOOK INSIDE TO SEE IF FROZEN LOOK TO SEE IF THE WALL WHERE TUBE GOES IN IS FROZEN,IF NO TO BOTH YOU HAVE A BAD INLET WATER VALVE,TURN WATER SUPPLY OFF,REMOVE PLASTIC TUBING FOR ICE MAKER AND DOOR WATERGOING TO WATER INLET VALVE,GET THE PART NUMBER AND GO TO YOUR LOCAL APPLIANCE PARTS STORE AND GET THE NEW PART,REPLACE TURN ON WATER AND ALL SHOULD BE GOOD,HOPE THIS HELP,THE WATER VALVE IS ON THE LOWER BACK SIDE OF FRIG.
Jun 07, 2008 | Whirlpool GS6NBEXR Side by Side...
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
210 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
