Question about Admiral AAV7000A
Grinding noise while agitating.
Put tennis shoes in washer, and within a few minutes in wash cycle, it started making a grinding noise during agitation. Didn't sound good, so turned it off, got shoes out, set to spin and drained water. It did that fine. got it back to agitation cycle to see if it did it again. Yep, it did...HELP PLEASE. Unit is 4 years old, never any problems before, except balancing with heavy loads.
  • 686 Answers
Possible foreign substance under agitator
Posted on Feb 26, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
How do you take off lid lock on cabrio washer model wtw5600xwo?
Unfortunately the lid lock id there to prevent the lid from being opened during the cycle so there is no way to do it.
Mar 07, 2012 | Whirlpool Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only...
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Dec 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Admiral AAV7000A Logo
635 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
