Question about JBL Venue SUB12 Subwoofer
JBL home theatre is humming endlessly. Please
JBL home theatre is humming endlessly. Please help on what is the problem?
  • 2 more comments
  • carlo193 Feb 26, 2009
    JBL subwoofer only is humming. the other speakers are perfectly fine. thanks for your help, any help is greatly appreciated. thank you. I just dont want to go spend more to fix it when I can buy a new one for the same price.
  • FunkedUp May 11, 2010
    Have you tried new/different leads? sounds like a short to me.
  • albert getty
    albert getty May 11, 2010
    sounds blown
  • albert getty
    is it in all spekers or 1
When I turn the volume control on my home powered subwoofer, it makes a humming sound, then it stop working
check your connections, RCA, Speaker wires, maybe there is grounded. try other wires which you think in good condition..
Aug 10, 2012 | JBL Audio Players & Recorders
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
When I hook the system up. I an hear a humming or buzzing like noise in teh system
This is the bane of all home theater installations and its called the "60 Hertz Hum" Most likely coming from your cable company.. Simple test... Disconnect any Coax cables from the outside going into your cable box or tv. Hum disappears. Most likely this is caused by a "ground loop" problem.
The solutions are far and varied. Google "ground loop hum" to find different things to try
Aug 14, 2009 | Philips HTS 6600/12 Home Theatre...
Humming from SUB333
Replace the plug, they most likely had a ground loop where it was plugged in and cut the common to get rid of noise. Replacement ends are easy to find at Home Depot, Lowes, ACE, etc. Try that first, if you still have an issue, post a comment and I can help you further. Hope this helps
Jun 20, 2009 | JBL ESC-300 Speaker
Overload on home theatre reciever
It would mean one of the power modules died. I believe they are STK412-530. Not an easy repair for a DIY.
Good luck
May 23, 2009 | JBL PP-600II System
Decode region on dvd player
Try 7385652500070000+INFO When You Put In A Movie Let Me Know If It Works.
Jan 19, 2009 | RCA RTD255 DVD Home Theatre System System
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
Jbl subwoofer
There is actually some good news.  I had this problem with my PB10s (1 have 2 PB10s and 2 PB12s) It is one of 2 things, the first is that it could be a capacitor and resister combination on the amplifier board (which was the fix for our PB10 with the same problem), or 2nd, the AMP IC, which is not available for the PB12. hmmm
Sep 10, 2007 | JBL PSW-D112 Speaker
JBL Venue SUB12 Subwoofer Logo
95 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
