Question about Hitachi 55HDT51 55 in. HD-Ready Plasma Television
I want to attach my digital camera to the tv. I have the proper cables but ca's find where to connect the yellow and black ends. Thanks for your help
    President:
  • Hitachi Master
  • 1,779 Answers
Yellow is normally Video, connect that one to Vidio In 1 and I would guess the black would be Audio if the camera supports audio, then that on would go into the same row as the Vidio except into the Red or White. Try that and let my know.
Posted on Feb 26, 2009
What colour connecting cable from camera to tv
Normally and standard, it's the yellow head cable. But sometimes if the yellow one doesn't work. Then try others. This won't hurt your TV or the camera.
Hope this helps
Sep 25, 2014 | Sony Cyber-Shot DSC-P10 Digital Camera
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I cannot show pictures on my tv from my sony 120 . I have the cords and the input on the tv but nothing happens when I try to show them???The manual suggest to delete the usb port???
You can either use the supplied A/V and USB Multi connector cable for connecting the Camera to the TV. Connect the Yellow cable to the Yellow port on the TV for Video and the Red and White for audio. Then select the proper input on the TV where the cable is connected.
You may also connect the HD Out of the Camera to the HDMI Input on the TV using the compatible HDMI cable for the Camera.
Before connecting the Camera to the TV, you may have to change the settings in the Camera depends on the TV type.
1. Component Settings from the Main Settings 2 Menu of the Camera should be set to HD or SD depends on the connection. Also depends on HDMI (HD) or A/V (SD) video connection.
2. Video Out Settings from the Main Settings 2 menu of the Camera should be set to NTSC or PAL depends upon the color system of the TV.
Try changing the settings in the Camera and connect it to the TV to view the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Is it possible to make videos with the camera
#1. Yes, if you've correctly installed the Canon solutions disk that came with your camera. Look in your Start menu under Programs/Canon Utilities. Look for a specific program in that folder called "RemoteCapture"
2. Yes again. You'll need an Audio/Video (A/V) cable to do such. One came with your camera (remember the black cable with the yellow plug). Plug one end into the "A/V Out" port on your camera, and the other end into the "A/V Input" on your TV. Put your camera in review or slideshow mode and view it.
The answer to these, and many more questions can be found in your camera's user guide, which may be downloaded directly from Canon (for free) here.
Oct 31, 2009 | Canon PowerShot A630 Digital Camera
Nikon Coolpix s550: Screen won't work
Please make sure no cable is attached to the camera. On many Nikon cameras, connecting a cable shuts down the screen.
Oct 05, 2017 | Nikon Coolpix S550 10 Megapixel Digital...
Canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Feb 20, 2009 | Nikon Coolpix 5600 Digital Camera
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Showing my video on TV from my JVC GR-DVL210A
Most places that sell cameras will probably also sell the cable that allows you to connect your camera to the TV. Depending on your camera, one end of the cable plugs into the camera and the other end probably has the Yellow, Red, White plugs that will plug into your TV.
You might also check the camera company website to see if they sell accessories specific to your camera.
Aug 11, 2008 | JVC GR-DVL210A Mini DV Digital Camcorder
Dimage E40 TV picture stability
In black and white? If there is a red and yellow, white and yellow, or red white and yellow on the tv end make sure the colors are matched correctly. Try on channel 3. Try on another tv. Is the camera from a foreign country? (Might be PAL, not NTSC.) If so, there should region menu in the camera to change this. For video, you have to shoot it in the mode of the TV you want to watch it on. North American TV's are NTSC, so shoot with the camera in that mode. If you shoot in PAL mode, a north american TV will show a black and white rolling picture. Just about everywhere else in the world is some version of PAL.
Sep 13, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Hitachi 55HDT51 55 in. HD-Ready Plasma Television Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
