Question about Plantronics Explorer 320 Wireless Headset
Pair 3xx plantronics with my phone
Could someone tell me procedure on paring 3xx Plantronics with my phone-thanks
    An expert whose answer gotĀ voted for 100 times.
  • 90 Answers
Turn on blue tooth on mobile first..then press and hold the power button on plantronics untill the light flashes red and blue alternatively...then search for bluetooth from mobile and pair and if asking a code enetr 0000..
Posted on Feb 26, 2009
  • Caryn
    Caryn Jan 17, 2014
    It worked but ONLY for speaking INTO the the phone calling the cell phone connected to the device. The phone didn't have the option to punch in a code. I HATE locked proprietary phones. It ALWAYS was an issue that's why I never buy them. Cheaper, in the long run to buy direct from mfg. or unlocked from other souce but NEVER direct from a provider. It just wouldn't work right but DID connect. Thanks though! He's going to just to to the service provider and demand an earpiece.
I want to pair my new cell phone with my headset 3xx plantronics but I need a passkey I don't have the instruction What can I do ?
Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 16, 2011 | Plantronics Explorer 220 Bluetooth Headset...
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a 3xx plantronics blue tooth. It is charged and ready, but for some reason it will not connect to my cell phone. It used, but not its not. What do I do to pair it with my cell phone?
Make sure cell phone is in discovery mode. Hold down power button on bluetooth headset until light starts blinking from blue to red. Your phone should find it. Then enter the code "0000".
Aug 24, 2010 | Plantronics Cell Phones
How do I put a Plantronics Explorer 232 in paring mode so I can connect it o a cell phone
Hold it in for three seconds or more to flash purple and enter discovery mode.
Once it's paired it will flash blue.
Default code is 0000.
Feb 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Can not pair Plantronics Explorer 220 on my LG enV2 phone
u have to follow certain guidelines to pair the device to your cell phone
first switch on bluetooth on ur cell then while your headset is switch off press centre button for long duration like 6 to 8 sec u will see that the blue light will be stable and continous then try to find ur headset in ur cell phone when u find it kindly select it and try to connect and if it ask for code type in 0000 four zeros and then it will pair up with ur headset you will see that blue light on headset will blink and then u can try calling
pls let me know if you have problems in the procedure i can provide more exact guidelines
pls rate me well !
Aug 27, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice...
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Jul 12, 2009 | Plantronics Explorer 330 Headset
220 Plantronics Head Set. How do I start the paring mode?
firstly make sure your blutooth is visible on your mobile phone. Now hold the on button and keep it held until your phone finds the paired device then press ok on your phone when it finds your handsfree device following your code.
Mar 10, 2009 | Plantronics - Bluetooth Headset Plus Base...
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 320 Wireless Headset Logo
7,373 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
