Question about Maytag Neptune FAV6800AW Top Load Washer
Fuse blowing on model #lat8440oaa w
This machine has worked well for the three years I have owned it, butrecently I blew a fuse when I started the machine. I replaced the fuse, a 1 amp 250 volt fuse and the same thing happened. the machine is in excellent condition but dates back to 1992. the model # is lat8440aa. My question is, what is causing the problem? Is it as simple as a lid switch or is it more serious?
  • 686 Answers
A short in a wire somewhere grounding causing fuse to blow
Posted on Feb 26, 2009
I have Hayward H400IDL2 heater 6 years old. I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater
Hi, this is John the Hayward tech. If you are now seeing the #4 fuse go that is on the low voltage side. I would guess the main circuit board. I left a manual on your other post.
Aug 24, 2014 | Hayward Pool & Spa
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
Tail lights work fine but no brake lights. Fuse keeps blowing whenever I replace the fuse.
check wiring on shift columb going to turn signal switch it could be the switch it self I had this happen on a new chevy truck hope this helps good luck jerry
Feb 16, 2013 | 2001 Jeep Grand Cherokee
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
The fuse in my Jensen JEN50 voltage converter blew and I need a new one. what size is this fuse?
Look at he fuse on the very end of the fuse there are some numbers. Amps and volts, go by that and replace it with the same exact fuse. If not , you can damage the equipment
Sep 29, 2009 | Kitchen Appliances - Others
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service?
yes.you can buy the switch assembly unit. it gets short and the fuse blows out.
May 04, 2009 | Washing Machines
Fan and lights come on and go off all day long on their own
We installed our Broan-Allure range hood about ten years ago. On three seperate occasions since, the fan has randomly turned on and none of the control buttons would turn it off. After a while it turns itself off. During those same times, when you turned the lights on, they would blink before finally staying on. On each occasion, I have removed the screens and metal underpieces to gain access to the circut board. Once you can see the circut board, remove and replace the 3 Amp fuse that is mounted on the board. (Radio Shack part # 270-1054)...even if the fuse looks good, replace it. Each time this has work for about three years, then it acts up again..
Oct 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Clarification for jl amp problem
sounds very much like resistance was an issue and no they dont have an internal fuse sorry
Oct 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
95 Geo Tracker Dash Lights out?
replace the blow fuse
above left knee, fuse panel there.
1 is blown.
your amp was shorted, it blew and took out what oem wiring they hacked into .
bad installation.
Sep 09, 2008 | 1995 Geo Tracker
Zanussi frost free fridge freezer
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Maytag Neptune FAV6800AW Top Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
