Question about Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
  • jdonread Feb 27, 2009
    Thanks but I should have said that the licensed KitchenAid repair guys replaced the fan to no avail.  If the fridge is turned off completely for 36-48 hours and turned back on, it runs perfectly for about a week.  then cold air is no longer pushed into the fridge compartment, the compressor runs constantly, and the freezer drops to -35. Also replaced were the two boards (computers), the two thermistors and the overhead panel. Nothing changes the situation.
    Sergeant:
    Champion:
  • Refrigerators Expert
  • 243 Answers
Checked Freezer Fan is working or not by pressing Door Switch.
If Freezer Fan is working properly then open Ref Door.
Check all duct by pressing Door switch air is flow or not
If air flow not getting that mins over frosting in Freezer
Switch of your ref from mains switch for 12hrs.
Do above step gain after starting Ref
If still not flow air in ref compartment then problem with Damper.
Damper work is to control cold air from freezer to Ref compartment
Posted on Dec 23, 2015
  • 686 Answers
Does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Posted on Feb 26, 2009
I have a daewoofrg1820brb I've had it plugged in 4 2 hrs now freezer is cold but the bottom isn't getting cold
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor. Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | Refrigerators
Drain water freezes in the back of the freezer compartment and no cold air gets to the bottom compartment.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Whirlpool ET1MHKXM Top Freezer...
Hotpoint side by side refrigerator. Freezer stopped blowing cold air while refrigerator side continued to cool. Freezer was totally thawed when I discovered problem but refrigerator side was still...
Hi
Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Also check whether the unit needs defrosting or not. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit
Please check the bellow links to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.applianceaid.com/frig_notcold.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint Refrigerators
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Refrigerator freezing lettuce. Adjustments result in freezer section too warm. I can't seem to find the correct settings. I can't locate my manual. This appliance is 25 years old or more.
a refrigerator thermometer is a good investment (usually available at grocery stores) .. i have two to make it faster to adjust things (one in freezer and one in refrigerator) ... first set the freezer with the temperature control .. set the freezer to 0 degrees F (adjust a little at a time until its close (wait several hours or a day between settings) ... then you may have another control called "air" or "refrigerator" .. you set that one for 37 deg in the refrigerator .. it usually takes a few days to get it right .. but without at least one thermometer you are flying blind, its nearly impossible to do correctly .. you can use any thermometer that is accurate down to 0 degrees, so you dont have to buy one if you already have one .. once you get it right you might want to mark the adjustments incase someone changes them ..
Nov 21, 2009 | Televison & Video
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
Refridgerator and freezer no longer cold!
Try disconnecting the fridge for a few minutes and then listen for the compressor to come on not just the fans.
Jul 02, 2009 | Refrigerators
Refrigerator won't get cold, top freezer is o.k.
There may be a fan and duct arrangement that blows cold air from the freezer to the refrigerator compartment.  That fan is controlled by the refrigerator thermostat.  If the door was open for a long time the fan might have been blowing cold air continuously and ice may have built up and blocked the duct preventing air flow to the refrigerator.  Check to see if you can hear the fan running.   You may have to press the switch that controls the light since that also sometimes turns the fan off when the door is open.  If you can hear the fan, check if there is any air flowing out of the vent holes at the inside back of the fridge compartment.  No air flow=no cooling.  If no air flow, unplug the refrigerator for a couple of hours to see if ice in duct will melt then start up and check for fan operation and cooling.  Frozen food in freezer will be OK if you keep it closed while refrigerator is unplugged.
May 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Refrigerators Logo
367 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
