Question about Fujitsu Siemens Stylistic LT P-600: Fujitsu Stylistic LT P-600 TABLET Stylistic LT P-600F, 600MHz Intel Pentium III ... (STYLISTICLTP600FUJITSU)
Is a processor upgrade possible
Will the motherboard handle a pllll processor and hence more ram
    Genius:
  • 1,066 Answers
No, it will not handle a pentium4, but you could get a much faster p3 for it. and the ram amount doesnt depend on the processor type, it depends on the motherboard and os. and it looks like 256 is the maximum ram for that model.
Posted on Feb 27, 2009
Problem playing video on my ASUS Transformer.
Hi Sam, are you familiar with the "buffer bar" when playing videos? It is the part of the video timeline that extends beyond where you've watched so far and it shows how much of the show is preloaded and ready for you to watch. If that buffer bar (usually grey) is too small or right at where you've watched to, then it means that something in your set up isn't fast enough to keep up with the show.
it could mean that you need to let your video start, and then pause it for a while to let it load before starting to watch. It may mean that you need to clean up your computer that may be bogged down with junk. Try using CCleaner from Pirform downloadable on Cnet
(Product reviews and prices software downloads and tech news CNET).
It could mean that your computer is simply not fast enough to handle never videos with higher definition that require more power to load quickly. So, if cleaing your computer doesn't help, then you may need to upgrade your RAM. Use ctrl+alt+delete to open the task manager, and use this to check the processor and RAM loads. This may take some googling to figure out. Processors can be hard to nearly impossible to switch, but RAM is easy, but may cost $40-$80 depending on what you need. Here is a website to find reliable products called Crucial (Compatible upgrades Guaranteed). It botched the link name, but it works.
Sep 11, 2015 | ASUS Transformer Book T100TAF - 10.1" -...
Is it possible to unsolder a processor from a motherboard without sacraficing it?
Unsoldering with a desoldering pump is easy. The problem will be soldering the new processor without overheating it. You would have to use a little flux and work fast. Perhaps put the heat sink in the freezer before you solder. Very strange to not have the processor in a socket so you can remove it.
Sep 30, 2017 | IBM ThinkPad X41 Tablet PC
When I power it up nothing comes up on the monitor??
1. check the RAM is seated
2. Try any other RAM
3. still the same problem check the video or graphics card , if any
4. if no graphics card and problem stiil changing it clear your CMOS by removing battery
5. if its new system then, remove battery, then take a small wire piece and short the positive and negative of the battery socket, then only CMOS is cleared
6. still problem , check the processor heat sink
7. still problem then suggesting checking motherboard and processor
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 11, 2010 | Gateway M275 Tablet PC
I have a Stylistic 5032D, running Windows XP
You can also switch your power settings to performance,
Which wouldn't use the CPU's built in speed step.
Speed step lowers the CPU's clock speed when not in use.
But this also uses more battery since the CPU's continually running at full speed at all times.
Good Luck
May 13, 2010 | Fujitsu Stylistic ST5032D Tablet PC
I have a Stylistic 5032D, running Windows XP Tablet, SP3. 2Gb RAM and 1.20GHz processor. I'd like to prolong its life - can I upgrade the processor or anything else to increase power? Thanks, Steve
Sorry no.
The CPU can't be upgraded as its a Pentium M 753 Ultra Low Voltage/ULV CPU.
Which is soldered directly to the motherboard.
And the max ram is 2gb which you have.
You can try a faster hard drive if currently you have a 5400rpm buy a 7200rpm drive, but this always brings more heat, and heat means lower battery life/time.
Good Luck.
Mar 22, 2010 | Fujitsu Stylistic ST5032D Tablet PC
I am using HP Laptop compeq presario c301tu when on the notebook the power led always blinking but here no disply
Dear client! You should check your RAM change slot use other slot for RAM if you have. It is very possible your problem will be solved. If problem remaining same you should your VGA it might be possible that it could be out of order and it will being not worked. If your laptop does not give any beep it could be possible your motherboard problem presist. But I assure that RAM will be out of order or RAM's slot fault so first of all you check your RAM or RAM's slot.
Thank You
Jul 25, 2009 | Tablets & eReaders
Break down of 160GB hard disk
Very old hdd. They have not produced a hdd smaller than 640GB for over 10 years.
Sep 27, 2017 | Compaq tc4200 Tablet PC
Harddrive exchange
Fredrik,
I don't know if you still need this info as you've not posted back here since your initial post but I finally took pics of the actual adapter from my V1100 that you'll need to install a hard drive in your tablet. Hope this helps and sorry about it taking so long.
Oscar
Oct 17, 2007 | ViewSonic Tablet PC V1100
Upgrading a Gateway M1200 to a M1300...
You can replace any motherboard, so long as your processor and memory are compatable and it fits into your case.
Mar 02, 2007 | Gateway M1200-3004265 Tablet PC
Fujitsu Siemens Stylistic LT P-600: Fujitsu Stylistic LT P-600 TABLET Stylistic LT P-600F, 600MHz Intel Pentium III ... (STYLISTICLTP600FUJITSU) Logo
393 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Martin Murray
Jason Morris
Lakshman P
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
