Question about Vizio SV420XV 42 in. LCD TV
Frame periodically freezes on Vizio 37'' TV
This TV is hooked up to an antenna with a booster. In the last week, it has frozen two times. The first time it was 1 1/2 hrs. later that I returned into the room and saw it frozen on the news station at 8:29 AM My 42" Vizio has frozen twice in the first two weeks we've owned it. I don't think reception or signal quality is the problem, as it's hooked to cable TV. djchillsync's solution doesn't apply.
    Scholar:
  • 32 Answers
Digital tv (or DTV) off the air is different from the old analog type tv signal. Both use basically the same type antenna, I use UHF on my dtv and that works. It used to be if the signal was weak you got a snowy picture, mostly white and black speckles. With digital tv signal there is no snow, the picture instead freezes and the motion of the tv picture stops (pixels may get mixed up too), it can't read what is next in the video so it stops to figure it out. When it gets a better signal it works, but you may have to redo the basic search for stations for the automatic configuration to get the best picture for the station to work good. A digital TV has a search function from the remote, dtv converter box has it too.
Posted on Sep 30, 2011
    President:
  • Vizio Master
  • 1,779 Answers
Your statement is confusing. Why? because you stated " This tv is hooked up to an Antenna with a Booster", then you said it's connected to Cable Tv. I will answer this both ways for you.
If your on an Outside Antenna or Rabbit Ears, even with a booster, if the signal is not good prior to getting to the antenna then a booster only amplifies what it see's and that may be as we call it, "garbage". In a HDTV the freezing can happen when that situation is at hand, however if you are on Cable and we know the signal is clean ( we hope? ) then the problem is with the software in the set and should be looked at by a service center, or if it's right out of the box then I would exchange it.
In digital technology there's no maybe, it's yes or no! If the signal is not what's required, then you get what your experiencing now, IF, there's nothing wrong with the set, and there may be. I just repaired another brand doing the same thing and it was the Main Control Module. So, I hope I helped you in isolating the problem. Please keep me posted...
Posted on Feb 26, 2009
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
The picture on our Vizio V0370M periodically gets darker, then after a while will lighten up.
If this is a brand new TV you may have a bad video card. The other, easier but pain in the but thing is you could be switching from a HD channel to a non HD channel. You will notice a difference. Last if you have an light sensor on the TV (adjusts to surrounding light) that could be tripping but you should have an option to turn that off.
Jun 16, 2011 | Vizio M370NV 37 in. LCD TV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
Same problem
Then I would say you have a problem with the Main Board in the 37". Have it looked at by a service company in your area if he wants to work on a Vizio. Parts are difficult to obtain at times.
Jun 08, 2009 | Vizio L37 Television
Just the one TV freezes
hello, it possible if your sharing the signal to sometimes loose reception you should have a dedicated hdtv antena or hdtv cable service for your main tv.
you can check by removing all the other sets and see,
if it happens again then you need a dedicated hd antenna or signal. this should be better for you and your hdtv reception.
Dec 17, 2008 | Vizio VU37L 37 in. LCD TV
HELLO to the guy saying hello ... I am on cable and have the same freezing problem ... so take the attitude and shove it!!!!!
Dec 17, 2008 | Vizio L37 Television
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
Vizio SV420XV 42 in. LCD TV Logo
349 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
