Overload I have a sterio system that is pritty old and alls it says is overload please turn off. the system I have is Technic SA-GX190 and i cant figure out how to get it working. Sorry i dont know what kind of manufacture the product is.
  • 4,234 Answers
The manufacturer is Panasonic which uses the brand name Technics for consumer products. The unit is shutting off because a problem is detected in the amp section. This particular model uses an Amp-pac which is a single component that contains the entire output amp. That part is likely to be defective. The part number is: RSN3306P and is available for $65.73 from tritronicsinc.com
Dan
Posted on Feb 26, 2009
When i turn my sa-ht40 on it says power overload
i have also the same problem with a panasoni SA-HT40. when i turn it on I see on the display OVERLOADED, and then thue unit turns off.
please help me
Jan 13, 2010 | Panasonic SC-HT40 System
Overload on sagx550 technics
Disconnect all speakers at the receiver then turn it back on. If it still goes into "overload" you need to have the unit serviced. If it stays on, post a comment and I can walk you thru troubleshooting your system.
Dec 22, 2009 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Balance Knob Technics SA-GX190
Sounds like a dirty pot. With the receiver off turn or slide it back from one side to the other. Test it, if its a little better you can clean it with a little (a drop or two) of wd40, You will probably need to remove the cover to get to it.
Nov 16, 2009 | Audio Players & Recorders
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Overload technics SA-GX390
It sounds like you have a wiring issue. Try looking for a bad wire or crossed wires between the positive and negitive jacks on the back of the unit.
Nov 06, 2008 | Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
135 people viewed this question
 Grubhead
Grubhead
