Question about Sony Grand WEGA KF-50WE620 Television
Blue ghosting all over the screen TV screen stays dark blue whether turned on or off. Indicator light keeps flashing green when TV turned on.
  • Sony Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneerblue ghosting all over the - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
I bought a samsung DNiejr 2 yrs ago and recently it has started making a sharp whistling sound. How can i repair this myself
The most likely problem is with the Switch Mode Power suplly (SMPS) However it cannot be confirmed as you did not mention whether the tv screen is dark or having any raster (lighted up).
Do you get the green LED ' Power on' indicator lighted up or stays red only.
If it is green your problem is either with the Horizontal/vertical output stage.
So state more about the current status of your TV
Apr 01, 2011 | Televison & Video
Hello, I have a strange problem. On my 2006 545i, the little green light indicator on the left of my headlight switch flashes on & off. The green indicator light used to stay off until the headlights...
Hello, what I have read in the owner's manual is that if there is an issue in the elestrical system, the light will blink telling you of the issue. The system needs to be at least scanned by the dealer to inform of what can be done to correct the problem. If all lights are working, I don't know if I would spend a ton of energy repairing it otherwise. Double check ALL of your lamps and "twilight" setting (automatic) for proper operation. Does everything else in the car illuminate as desgined? I have an owner's manual for 04 if you would like it. If so, email me at iambanshee74@yahoo.com and I will send it out immediately via email.
Feb 11, 2011 | 2006 BMW 545i
The screen doesn't go on when the power to the TV is turned on.
View your screen from a flat angle while on a known active channel to see if you can detect any 'ghosting' of images.
I think either the back-light or the high voltage supply for it has failed.
May 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen dark,wont stay on. 52hm95
Here's the online manual for your TV:
http://www.tacp.toshiba.com/tacpassets-images/models/42HM95/docs/42HM95_om_e.pdf
Read the section about the red/green lights in front. It sounds like the lamp went out. Mine consistently goes out once every year to year and a half. If you plan on keeping the television, purchase two bulbs, so you have one on hand in case your new one goes out.
Good luck.
Apr 19, 2009 | Toshiba 52HM95 52" HDTV Projection...
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
1.5 days after replacing both IC chips the blue started ghosting again and then...
The biggest problem you stated yourself. You bought aftermarket type IC's. You should have been smarter and purchased the correct IC's for the set. All IC's are not alike, even with the same number on them. Aftermarket IC's are just that. Built in China or are factory rejects. You might get away with replacing the iC's again from a reliable dealer or you might have messed up the power supply in the meantime. Good Luck
Mar 02, 2008 | JVC AV-48WP30 48" Rear Projection...
Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Sep 16, 2007 | Hitachi 51F510 51" Rear Projection...
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
