Question about Acer Aspire 3680 Laptop
The LCD screen on HP ze1250 dim,external monitor works fine. How to replace the backlights and where do I get the parts?
  • Acer Master
  • 32,281 Answers
The problem could be a faulty inverter or the backlight fluro light lamp. The inverter is easier to replace than the fluro lamp.
Google the WEB for replacement parts and instructions on replacing the lamp. There are quite a few helpful sites for parts and repair instructions.
Posted on Feb 26, 2009
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
My laptop monitor flickers ramdomly....the grafix
This could be a faulty CCFL lamp.
Check out
www.lcdparts.net
Jul 14, 2009 | HP 510 Notebook
Nothing appears on the display.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 07, 2009 | HP Pavilion ze2000 Notebook
LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
May 23, 2009 | Dell Latitude L400 Notebook
Dim Laptop screen
It could either be your power settings dimming it (battery saver mode), or more likely when you replaced the screen, you replaced the backlight with the one that came with it. The replacement backlight is probably not as good as the one you had. You can try putting your other backlight in it (the backlight is that circuit board near the hinge that you plug in when you switch the screens out). Since it's going in and out, I'd check the power settings first though.
May 04, 2009 | IBM Computers & Internet
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 31, 2009 | Dell Precision M60 Notebook
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Just replaced a cracked screen in a toshiba a105-s4074....when i turn it on i can barely see the screen....it is very dim.....when i plug the old cracked 1 up it works fine....any suggestions?
If you see a dim image on the LCD screen it means you have a backlight problem.
Mar 10, 2009 | Toshiba Satellite A105-S4074 Notebook PC
Acer Aspire 3680 Laptop Logo
133 people viewed this question
Brian Sullivan
Brian Sullivan
