Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
My mac book pro will not read dvds after I formated the machine.. I did a hardware run and everything seems to in top condition....... Can anybody help?
  • Computerdok Apr 15, 2009
    My MacBook Pro dont want to read any DVD. It plays music cd but no DVD. Any reason why my computer dont want to open my DVD's?
  • 32 Answers
I just replaced my drive on same mac recently, the leapard on the drive setup all on its own look under disk utility for setting of dvd might have reinstall system again have u got it on disk.
actionman
Posted on Mar 01, 2009
Crashing
its not the mother board you need to up grade (yourself as in apple will not do it for you) the ram to at least 8 gigs and get a new mac book pro processor that runs on at least 80 gigs
Mar 15, 2013 | Apple Mac Book Pro 13 In Laptop Computers
External Monitor reads, Power saving mode on a Mac Book Pro. Monitor is a Dell ST2220L.
Make sure that the monitor is set to the correct input. On the Mac, got to displays and verify that the machine sees both screens.
Nov 10, 2012 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I burned a dvd on my MAC book pro, but it won't play on Sharp dv-rw340 vhs/dvd combo. The disk plays on other machines, so I know it works. Any suggestions?
Hi there. I would suggest looking at your owners manual to see what formats are supported by your player. It may not support recorded dvds.
Mar 30, 2011 | Computers & Internet
Hi Gurus ..My Mac Book Pro has destroyed 3 USB memory sticks so far... physical damage that no formatting soft or hard on both MAC or PC worked. It happens as soon as I stick the drive in... I read that a...
It's possible your USB slots have a lot of dust, or could be physically damaged and is causing shorts. If three USB drives have already been damaged, your best bet is to send the mac book to apple for inspection. If your warranty is up, or you're feeling adventurous, you can open the Mac Book your self and have a look at what's going on near, around, or on the USB ports.
Mar 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Trying to get it work with my power book pro
go to spotlight (magnify glass at top right corner) and type disk utility
format the hard drive with mac os extended
you should be able to write files and read files to it now.
Mar 12, 2011 | Western Digital My Book Essential 1TB...
I have a new macbook pro and want to copy files from my PC to my Mac. As advised by the Mac store I first plugged my MyBook into the Mac (which presumably formatted it and has set up Time Machine). ...
Hmmn. Far easier, I would think, to share the files via the network (if both machines are on the same network.) Check this link:
http://www.ifelix.co.uk/tech/3001.html
Using the MyBook would be faster if there is a LOT of data, though.
What OS are you running on the PC?
Sep 25, 2009 | Western Digital 500GB My Book Pro-External...
CD / DVD ROM problem, can read cds or dvds that I create
Sounds like your need to install the codecs. Here's a good set of them: Download the full version and you might also want to check your dvd decoders,
http://www.free-codecs.com/download/K_lite_codec_pack.htm
May 20, 2009 | ASUS R1F-K049E Tablet PC
How can i get get WD "my book" hd to also work with windows
Some solutions possible:
(Optional: - First split the video in chunks <2GB to make them more compatible with older filesystems and networking technologies)
A) Copy the file over the network (e.g. using Windows Sharing on the Mac, or using File and Printer Sharing on Vista)
B) Try to do it via the MyBook.  This means the Mac must be able to write something and Vista must be able to read it.  You say you've "set up" the MyBook "for my macbook pro".  How did you format it?  What filesystem?  Mac OS Extended (HFS+) with Journaling?  In general, you need to install something on Vista to read the Mac's filesystem format (HFS+), or on the Mac to write a Windows format (probably best to use NTFS).  Examples of software like that are:    (Win) MacDisk <http://www.macdisk.com>, MacDrive <http://www.mediafour.com/products/macdrive>    (Mac) MacFUSE with NTFS-3G <http://macntfs-3g.blogspot.com/>       or Paragon NTFS <http://www.paragon-software.com/home/ntfs-mac/>
B2) If you've formatted the MyBook as FAT32, you're lucky.  Just split the movie file in chunks <2GB, copy them to the MyBook, copy them from the MyBook in Vista and join the chunks again.
(for splitting you can use e.g. HJSplit and its compatibles <http://www.freebyte.com/hjsplit/>) (also check e.g. "NTFS on your Mac two ways" <http://www.tuaw.com/2007/11/19/ntfs-on-your-mac-two-ways/> for an alternative explanation.)
Jan 29, 2009 | Western Digital MY BOOK HOME 1TB EXT...
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
1,507 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
