Question about Maytag MSD2456G Side by Side Refrigerator
Ice maker maker horrible noise when activated
The icemaker makes at horrendous noise when we try to get ice. THe ice bin pushes away by itself. The icemaker has been dripping water into the bin building up ice everywhere in the freezer. COuld it be the solenoid, the water works fine. IT doesnt want to make ice unless you clean the ice away, however lately it won't make any ice. Help
Maytag plus mzd2766ges
  • gdtconstinc Feb 27, 2009
    OK, its not the bucket, its seems that where the control rod goes into the yoke assembly, the yoke assembly is really hard to go up and down. so it does activate anything. Its like it is frozen. THat is why I thought it could be the solenoid. The ice maker engagement yoke turns. It just seems like the water doesn't come out to make ice.
  • 686 Answers
Take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Posted on Feb 26, 2009
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
My icemaker on my whirlpool refrigerator will not make ice. It seems that no water is coming to the icemaker. I emptied the ice bin and it will not make ice.
Either the water valve that sends the water in is bad or the ice maker itself is bad or your filter needs changing if you have one.
Sep 28, 2014 | Whirlpool Refrigerators
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
The icemaker is not making ice as fast as it would before. It dumps a tray of ice about every 4 hours.
Make sure that there are no kinks in the water line.
Next, inspect the feeler arm of the ice maker and make sure that it is down and not blocked by any ice cubes. If it's raised, it has turned the ice maker off. This arm needs to be in the lowered position to activate the ice maker An over-abundance of ice in the bin will make the arm stay up as a safety feature to keep the ice maker from making more ice than the bin can hold.
Jul 30, 2011 | Refrigerators
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Icemaker seems to be stuck, making strange noise and not producing ice
first of all they make a few different kinds of i\m let alone models and brands of fridges, if its electronic then the module is propably broken
Jul 07, 2009 | Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
Ice maker
This means that the tray is not getting cold enough to freeze the cubes. It must be no more than 12 degrees F for the icemaker to cycle properly.
Make sure your freezer is cold enough. If it is, then the other possibility is that the heater element in the icemaker (which thaws the cubes JUST ENOUGH for them to be pushed out when ready) could be stuck on. This can be easily tested, but the process is a little beyond the scope of this reply. Check this link http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 16, 2008 | Samsung RS2556 Side by Side Refrigerator
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Feb 13, 2008 | Refrigerators
Maytag MSD2456G Side by Side Refrigerator Logo
273 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
