Question about Garden
Lamnmomer wont start .need to replace spark plug.need to know gap seeting for .my lawnmomer is a yardboy with briggs&stratton engine 6.5 -7.o hp
    Problem Solver:
  • 10 Answers
Here are two things.
First the spark plug. Take the one that was in it to the where they sell small engine spark plugs in your area. The people working there will be able to easily match for the right one. As far as the gap goes, you can look at www.briggsandstratton.com and find the manual for you mower, the gap setting should be in there.
Now for the not starting. If the mower is in good repair otherwise, I've found that most of the time if the mower has been sitting since last year, the gas has gone bad. You can usually tell by taking the cap off and smelling the gas in the tank. If it doesn't smell normal, you will need to drain the bad gas out of the tank -and the bowl of the carburetor. Most carb bowls can be drained by unscrewing the bolt in on the very bottom of the carb. Be careful, because a lot more gas then you think will drain out. Once that is done replace the bowl bolt and fill the mower with gas and try starting the mower.
Also, be sure to clean up all the gas that you spill on yourself and anything else before trying to start the mower!
Posted on Feb 26, 2009
What is the spark plug gap for Briggs 20.5 hp
For a proper answer more info is needed. Here's a Briggs site that has spark plug gaps listed. Gap is not hyper critical for running.
.030-.045 will work. The only time I've seen gap matter was when it was too close like .005, the engine wouldn't run.
What is the right spark plug and gap for my small engine Briggs Stratton
Sep 21, 2017 | HP Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Why is there no fire to spark plug on 6 hp brigs & stratton engine
replace your ignition module and or coil,i dought you have points and condenser,so basically that's all that is left
Aug 01, 2014 | Briggs & Stratton Garden
Oil coming from valve cover
did you gap spark plug to.028" ? may need to replace the valve cover gasket.
May 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Spark plug gap for a rc12yc on 22 hp engine
Gap setting for a Champion RC12YC spark plug is .030
Apr 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I am replacing the spark plug on a 5 hp Quantum engine that is on a Troy Bilt walk behind mower. I would like to know the spark plug gap setting on that motor.
I'm guessing you have a standard Champion J19LM plug, which has a gap of .030. They come pre-gapped from the mfg. and usually no need to adjust them. Most of the plugs on these engines have a .030 gap. There are very few exceptions that use a .020 gap (such as the RC12YC). Anyway, here's a link to a chart I like to use for reference: (there's a drop down menu at the top to change engines, but the standard Briggs engine is the one here).
http://www.manddsmallengine.com/briggs/info/plug7.html
Hope this helps. James
Aug 06, 2011 | Briggs & Stratton Garden
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
