Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Can i change my hard disk plettor - Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
    Scholar:
  • 116 Answers
Yes! IF you have a clean room....
Hard disc platters write on a surface 1/20th the size of your hair. So even dust you cannot see will destroy the data as you try to use it.
So simple answer is no. you cannot change the platter, unless you have a clean room :)
Posted on Feb 26, 2009
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
Computer does not see hard drive. ran diagnostic test Testing booth path Error code biohd-2 no drive detected
reset the bios then check the power connector and the IDE or SATA cable for loose contact or change them see whether the hard disk is spinning or making any noise if you hear noise the hard dis is need ed to be changed if the hard disk is not spinning check the power connector and also check whether the circuit board below the hard disk is getting hot if its getting hot you need to change the circuit board of the hard disk with same company and number
Apr 25, 2011 | HP TouchSmart IQ506 PC Desktop
No hard disk found
check if u have connected hard disk wires properly.
on n check if u can feel that the power comes in the hard disk by touching it. it should be open.
try putting the hard disk in another pc or note book and check if its picks there..., if not then ur hard disk is not workin n need to get another hard disk. if it picks then recheck ur note book if u have connected the wires properly n try changing hard disk wire and power supply wire n see if it works or not.
thank you...
shakeel khan..
Apr 13, 2011 | HP G60-235DX Notebook
My laptop does not boot. it always ask for a cd to boot but i already reformat it.someone told me that it is a hard disk problem and advice me to replace my hard drive.
When the computer starts it flashes up press f2or delete or some other key to enter setup. Go through the settings and there should be one that will allow you to change the boot device. It sounds to me like it is set to boot from the cd rom drive only. Change it to boot from the hard drive and save changes to CMOS and restart the computer. The computer should now boot from the hard drive.
Aug 01, 2010 | Compaq Computers & Internet
Changed rights in Vista -> Can not change them back! (disk drive)
download active boot disk pro. it is free. run the disk and remove all passwords and start over. :)
Feb 11, 2010 | Microsoft Windows Vista Home Premium...
Hard drive failure
you should replace with a SATA laptop hard disk....
Feb 10, 2009 | Acer TravelMate 3260-4874 Notebook
Hard Disk hangs
You have to give it for reairing or buy a new hard disk..
Aug 22, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Change of Hard Disk
well,you can install any size you want and make sure you reboot from the cd rom when you reinstall the disc toshiba are hard to reboot sometimes unless you have the reboot disc .. lala linda
Jun 03, 2008 | IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
74 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
