Question about Casio ClassPad 300 Calculator
Incorrect answer when expanding on casio classpad 330
Whenever i go to expand a problem, i just get numbers separated by commers. However when i used to do this all the answers with their co efficient would come up. Does anyone know how to fix this?
Thanks?
  • Casio Master
  • 7,993 Answers
I don't quite understand what you mean by expand a problem. The expand( command is used to develop expressions such as (ax+b)^2.
For this expression the calculator will give a^2.x^2+2.a.b.x+b^2, which is the correct answer. The dots stand for the multiplication sign.
If you tell us what you are trying to do, we might be able to advise you better.
Hope it helps.
Posted on Oct 10, 2009
Phasor addition on classpad 330
Open up keyboard, go to 'cat' tab and scroll down to get ' <( ' symbol.
Input the magnitude followed by angle separated by a comma (E.g. <(15,10) ). The first element in the bracket is the magnitude of the phasor while the second element is the angle.
To do phasor addition simply add more of the '<(' symbol. (E.g. <(15,10) + <(12,5) is the addition of phasor_1 with magnitude 15 and angle 10 and phasor_2 with magnitude 12 and angle 5 ).
Note: the symbol ' <( ' appears at the very bottom of the list and the '<' symbol is actually more flat in appearance like how a normal phasor is usually represented.
Apr 09, 2014 | Casio ClassPad 330 Graphing Calculator
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Classpad 330
Here is a screen capture that may help you. Variable must be x. Be careful what type of brackets you use to enclose the arguments. use the ones that are on the same line as Pi, theta, i.
Sep 19, 2013 | Office Equipment & Supplies
My Casio classpad won't give me the correct answer
I am not sure about what you want. The expression is in its most compact form. So I am assuming you want to exapnd it. The command for that is exapnd( . Just type it using the keyboard or look for it under the Action>Transformation menu.
expand((x+5)^6) [EXE]
Here is a screen capture of what you should get. Notice that I cleared all 1-letter variables to erase any value stored in x.
Jul 11, 2012 | Office Equipment & Supplies
Whenever the command expand, diff or integrate are use it comes up with wrong argument. I have tried to clear all variables and default the set up but to no avail.
I believe you are using the wrong syntax for the commands.
diff ( function, variable) Example: diff (sin(x^2), x) sgould give you 2.x.cos(x^2)
expand( will expand an expression that has parentheses: expand( (a+b)^2) will give a^2+2a.b+b^2
Integrate $
$ ( tan^-1(x), x) willl give x.tan^-1(x) -(1/2) ln ('x^2+1')
Check the syntax of a command before using it. You will find the list of all comands and their syntax in the reference manual.
Aug 22, 2011 | Casio ClassPad 300 Calculator
How do I enter degrees minutes seconds on casio classpad 330
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
May 12, 2011 | Casio ClassPad 300 Calculator
Can you update a classpad 300 to a 330 operating system
It depends. If the ClassPad has OS 1.x you can upgrade it to 2.x freely. However you need to buy (separately) the ClassPad manager 3.x to be able to upgrade the OS to version 3.x. After that further upgrades appear to be free.
Feb 05, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
How do i enter degrees minutes seconds on classpad 330?
Sep 06, 2010 | Casio ClassPad 300 Calculator
Casio Classpad 300 plus
I bought a classpad 300 plus but I dont know how to operate it. I saw some books for classpad 300 and I really want to buy some. However everytime I try to buy, there is always a classpad that goes with the books . Can I buy books for classpad with out buying a calculator anymore?
Sep 13, 2007 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
314 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
