Question about Adobe Photoshop CS for PC
Photo shop cs already installed but help file is not open
Uninstall and re-install the product.
Posted on Mar 19, 2009
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
Hi there, How do I print my image on A4 without any margine. Thanks
Hi
u don;t want to use adobe phot shop, just copy your jpag file and open word and paste there and drag your photo and increases your photo size. this is tempo-rely option, Best u Install the Abobe Photo Shop.
Good Luck
May 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have problem opening the photos from a friend in picassa
Hello
This problem can be resolved by opening the "Control panel" and selecting "All Profiles" under the "Color Management" file. Add the "sRGBIEC61966-2.1" profile to the "ICC Profiles."
Make sure that the digital photo file that you're trying to access isn't open or in use by another program on your computer. Oftentimes, two programs can't access the data contained within a file at the same time. If your photo is already open in another program, for example, you wouldn't be able to open it in your digital photo viewer/file manager.
Make sure that the file format of the digital file you're trying to open will actually work with the file manager you're trying to use. Not all programs are going to be able to open every file type. There are dozens of different photo files types in existence. Look at the photo file's extension and then look in the instruction manual that came with your file manager to determine if that program can read that particular type of file.
Reinstall your digital photo viewer file manager utility. If you purchased your program in a store, insert the CD-ROM you used to originally install it into your computer and select "Repair" when its setup program automatically opens. If you installed your digital photo viewer file manager utility from a computer file you obtained on the Internet, execute the original installation file and select "Repair" to reinstall your program on your computer.
Make sure you have the latest version of your digital photo viewer file manager. Programs are often updated by their original manufacturers to fix errors and issues that users have been known to have. Open your program and click on the "Help" tab. Look for an option that reads something like "Update" or "Check for Updates" and select it to connect to the Internet and make sure that you have the latest version of the program installed on your machine.
Nov 05, 2010 | Computers & Internet
On my window no photo shop cs 4 installed
well actually photo shop CS4 is not already installed in your window. you need to install it. and for that you need to get the setup for the same. so you can buy this online and also purchase the PHOTO SHOP CS 4 from its official website of ADOBE. hope my this advise will help you..
Jun 26, 2010 | Microsoft Windows XP Professional SP2
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
Aug 10, 2009 | Adobe Photoshop Elements 2.0
Need a driver for a CanoScan N670U Scanner for Mac 10.5 OSX
Basically you should not scan through Photoshop but should use your scanning software as a stand-alone application
Apr 23, 2017 | Canon CanoScan N670U Flatbed Scanner
I want download my photos from mobile to p.c.I
try to connect mobile to pc by installing the mobile driver on to the computer and access the mobile memory, through which you can copy to system or open the files in Adobe Photoshop
Apr 28, 2009 | Computers & Internet
Autorization code of photo shop Cs2
You need to contact Adobe.com customer support.
Mar 16, 2009 | Adobe Photoshop CS for PC
Acrord32 error
try to uninstall Adobe and install it again. It helped me.
CS.
May 16, 2008 | Compaq Presario 5000 PC Desktop
Open RAW files
1- Be sure your files from the Olympus are downloaded and stored on your hard drive. 2- Be sure you've updated Photoshop CS' Camera RAW to the latest version: go to http:// www.adobe.com/support/downloads/main.html and click on the OS platform of your choice for Creative Suite, pick the latest Camera Raw plugin to download. Install and you're ready to go. 3- Start up Photoshop CS. You can either use the File Browser to look at the directory where you have put the files from your camera, open them from there, or you can use the File->Open... menu commands to pilot your way there and just open the file you choose explicitly. Camera Raw will start automatically when you pick a .ORF file with either method.
Sep 13, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Adobe Photoshop CS for PC Logo
67 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
