Question about Maytag MDE2706 Electric Dryer
Dryer overheats and shuts off
I bought a dryer from someone recently and when I hooked it up it will run for about 4 min and then shut off for about 6 min and then start up again for 4 and so on. The dryer is getting too hot and shutting itself off. There is nothing wrong with the dryer it's the vent hose that leads to the outside of the house. When the hose is on is when it gets too hot and shuts off but if you take the hose off it will run its full cycle. I have made sure that the hose is free of lint and the vent is clean also. From the dryer to the outside is only about 3 feet so I can look in the hose and see there is nothing blocking it and I can reach my hand from the laundry room out the vent to the outside so I know that is clean. I held the flaps wide open on the outside of the house and it still shut off after about 4 min. I don't know if I need to make the vent on the outside of the house bigger to allow more air out but the air is getting backed up somehow, any ideas?
  • 547 Answers
How long is your vent hose and how long when heated it may be kinking when heated
Posted on Feb 26, 2009
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
Dryer runs for about 20 min. then shuts off will start after it cools down and run again for another 20 min.
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out.
Sep 19, 2011 | Kenmore 66832 Dryer
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
My laptop Sony Vaio CS 320J is shutting down with out any notice(not proper shut down but poweroff while running) and not booting again for @ least 2 mins. recently this issue started and this is...
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Apr 15, 2011 | Sony VAIO VGN-CS320J Notebook
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
My kenmore dryer will start and run when cold after it heats up the flame (gas dryer)goes out then after 3 or 4 mins. i can see the igniter light but will not start a flame after 5 or 6 seconds the igniter...
gas valve coulkd be bad if not opening after a certain period of time the ignitor will turn off and attempt a few times more,does it have a soilenoid valve also open and clean any carbon that might be built up over yrs
Jun 21, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
I would take and get a lint brush and clean the hose and I would also make sure you clean the pipe that is running on out side plus make sure the flap is opening up outside like it should .
Feb 26, 2009 | Dryers
Maytag MDE2706 Electric Dryer Logo
497 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
