Question about LG RD-JT30 Multimedia Projector
YPbPr and YCbCr signal
I am using an LG RDJT30 projector, which is connected to a Pioneer DVD player thru the component connector of Denon AVR 3805.
Recently, I bought the DVD of Wall-E and while watching, all of a sudden the screen would go blank (blue) and the “no signal” would display, and then the projector would skip either between YPbPr and YCbCr, after searching, the picture would return after some time, and then again, it would start all over again and then some section it would be all right and then go back to the same problem.
When I connected the same thru the composite RCA connection, then the movie would play all right. The DVD when played and connected thru HDMI input on my plasma, it worked fine.
I am wondering whether it is a problem with the:
1). DVD: Bad recording???
2). Denon 3805 : upscaling problem?
3). The Projector itself ?
Or the
4). Pioneer DVD player?
This has happened once or twice before also on some other DVDs.
  • Sachin
    Sachin Mar 03, 2009
    I found out the problem with the DVd itself. It was not recorded properly... and therefore was not sending signal to the projector, whereupon the projector was looking for signal
  • 2,237 Answers
With component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Posted on Aug 19, 2009
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
Video does not work All this while, I had never used the video components of my AVR 1705. Recently, i wanted to connect the component out of the cable set top box and dvd player to the avr and the output...
Hi
The settings on many DVD players and TVs may need to be set to indicate the type of input/output being used(RGB vs YUV/YPbPr, and if set wrong the image may not be properly displayed. Try Look for such settings in your TV and/or Amp!
Good luck
Bruce
Dec 07, 2009 | Denon AVR-1705 Receiver
How do u connect the surrond sound on the blue ray dvd player
you are tring to connect the dvd to the reciever?
if so use the red, green, blue component connections plus optical or coaxial audio from the DVD to the DVD input on the reciever and the red, green, blue component connection from the reciever to the tv
Jun 16, 2009 | Denon AVR-3805 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Video Monitor Out issues
Just to be clear, what is the input you are using on the projector?
Thanks,
Dan
Apr 18, 2008 | Denon AVR-3805 Receiver
LG RD-JT30 Multimedia Projector Logo
363 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
