Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Washer won't spin and drain
Frigidaire washer fills up fine, does wash, but doesn't empty water or spin. Hose is not clogged. Empties manually just fine when hose is disconnected and emptied into laundry sink. checked all cycles and same problem.
  • 686 Answers
Bad lid switch
Posted on Feb 26, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Frigidaire Front load Washer Does not spin (Drains fine, Water comes in fine)
Hi John - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. The humming noise is mainly caused due to the drainage hose/pump possibly being clogged and needs to be cleaned. If not, the washer may be experiencing another possible issue with the faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 02, 2013 | Frigidaire FTF530FS Front Load Washer
The washer will not drain after the rinse cycle
Three main causes for water not draining are listed below:
  1. Clogged drain tube - exhaust or relief tube the hose empties into (does not apply if hose empties into a sink)
  2. Clogged drain hose - occasionally, debris from the wash will find it's way into the hose and clog, backing water up into the machine
  3. Clogged drain pump - like the drain hose, debris gets jammed into the pump. It may take a while for the pump to accumulate enough debris before it clogs. Disconnecting the hose under the washer will occasionally leave enough room to dig out any clogs in the pump. If not, the pump may need to be removed to clear the obstruction.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water will not drain, makes a noise when filling, pump does not seem to be froze up.
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Luckily, your drain pump is easily accessible. Placing a towel or blanket down, unplug the machine, disconnect the fill and drain hoses and gently turn the washer forward onto the towel or blanket. Only tools needed are a pair of pliers and a phillip head screwdriver. After removing the drain hose and the screw holding the pump in place, it should easily be removed so you can inspect for debris (a very common problem with F&P washers.
Best of luck with your repair.
Greg
Jul 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
I manually put water in my washer; water stuck inside
drain hose kinked or belt off pump . lower drain hose to floor if empties the pump is the problem
Apr 17, 2009 | Whirlpool Washing Machines
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Waher fills up and empties at the same time
you definalty have a drain hose issue, id bet that either your drain hose is lower the nte hunit itself or even connected to and outside drain sorce with out any "air gap/brake" i the drain line.. your creating a siphon action, you drain line should drain into a stand pipe no lower the n the back of the units console
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
207 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
