Looking for one of those screwdrivers that have many different bits that are sometimes stored in the handle. So you can easily change them without having to carry many different screwdrivers. The problem is that all that i see are cheap ones that get easily damaged when i use them. Are there more expensive all-in-one screwdrivers that have bits made of better metal? Are there screwdrivers like that that are electric?
The ones I like the most are called Megapro It has the bits in the handle. You pull the back of he handle out and the bits are snapped into a holder in the middle. The screwdriver is grey, and the backcaps come in several colors. They also make a yellow one with all stainless steel bits.
It has a good assortment of bits and the local chain that sells them, Tacoma Screw, also carries replacement bits. The bits are double ended and are held into the screwdriver by a ball-detent, not a magnet, so you don't end up with iron fuzz all over it.
Here is their homepage
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
pandamama - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Cluthe brand . Not even expensive but pretty decent quality . Luck
Ken Cutt
Was this helpful?
Yes
No
Solution #3
Pasty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Second this recommendation. Mine was made in the USA. The only problem I have with it is that it keeps getting borrowed. 8-(
Best regards, Spehro Pefhany -- "it's the network..." "The Journey is the reward" Info for manufacturers: # Embedded software/hardware/analog Info for designers: #
Was this helpful?
Yes
No
Solution #4
Luisa_K - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Stanley use to make one in the pump type format but I don't know if they still do. -- Neil My address is Spamless.
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
Picked up an electrical one rated at 5000(?) volts at Walmart, been using it for about three years now on a regular basis. Replaced the #2 Phillips a couple of times and the lettering is worn off, but it still works good. If you want to go a little further upscale, Wiha has one also, I have one also, but tend to use the Walmart one as it fits in my pocket better.
Was this helpful?
Yes
No
Solution #6
pawa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
For what it's worth... $nap-On makes an 8 in one pouch affair (SDDD44) thats excellent.
Has a handle and 4 double ended bits...
3/16" slot X #1 Phillips
1/4" slot X #2 Phillips
5/16" slot X #3 Phillips
T15 X T20 Torx
Had mine for years, keep it in the desk. The typical red $nap-On pouch measures about 4 3/4"W X 6 1/2"H.
I got it as a gift... just looked it up on their site. !!!WARNING!!!, NOT FOR THE FAINT OF HEART! (sorry about the long address, you may need to copy and paste to get it to work)
i have an E:df fault code on my washer. unplugging the unit and repowering doesn't solve the...
(More)
i have an E:df fault code on my washer. unplugging the unit and repowering doesn't solve the problem. how do I check the motor and tachometer circuit open? Thanks, Jacob
hi i have a aeg lavermat turbo 12710 upgrade the door wont open and it stops half way throyugh...
(More)
hi i have a aeg lavermat turbo 12710 upgrade the door wont open and it stops half way throyugh driying and washin can u help with this problem
My AEG Lavamat Turbo 12710 Update - Dryer program selected - pump starts and then fan starts but no...
(More)
My AEG Lavamat Turbo 12710 Update - Dryer program selected - pump starts and then fan starts but no heat from heaters. Heaters testing ok at 56 ohms with no earth faults. Both Heater thermostats closed ready to operate. Sensor at front of machine in duct above door is open circuit but dont know if this is a symptom. Any ideas? Does anyone have a circuit diagram.
We have a Lavamat 12700 that's a couple of years old. It has started halving the drying time - i.e....
(More)
We have a Lavamat 12700 that's a couple of years old. It has started halving the drying time - i.e. we put it on for an hour and it stops after 30 minutes. In addition, there are occasions when the drum does not heat up at all. One engineer advised us that it was possibly a power spike but this seems implausible as it now happens far too frequently. We have done the usual "reboot" of mains power etc.
Any ideas? Do we need to replace the control unit? Any idea how much that might cost?
Thanks for your help.
