Question about Microsoft Windows 98 for PC
I am using windows 98 .when ever i start my computers it is showing error A FATAL EXCEPTION 0E HAS OCCURED AT 016F:BFF8D18A AND COMPUTER REBOOT AGAIN PLEASE GIVE ME SOME SOLUTION.
    Novelist:
  • 121 Answers
Sounds to me that a program installed isn't playing nice with Windows 98. I would go into safe mode and remove what ever software was recently installed or do as the link says and remove Antivirus program. If you can't get into safe mode I would have to tell you to reinstall Windows 98.
Have a good day,
ArmyMason
Posted on Feb 26, 2009
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
Jun 20, 2013 | Computers & Internet
When iamopening fire fox or ie 8 for browsing my system shows error the exception unknown software excepion 0*0000417 occured in the application at location 0*78b2ae6e
Try rolling back with System Restore. It can be found in help, right clicking My Computer, or typing System Restore in Search.
You may need to try a few dates, prior to the problem starting.
Dec 24, 2012 | Computers & Internet
I can not open my skype,my computer show me that I have fatal error:faild to get proc address for encode pointer(kernel 32.dll)
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
or you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
also you might need the skype manager downloaded
http://skype.en.softonic.com/universaldownloader-launch
hope this helps
Feb 12, 2011 | Computers & Internet
Sony vgc RB 30-I was putting in a graphics card on Friday for a dual monitor-vision Tek 7K 64MB DDR VTKRad7K64P. it said in the spotty directions to remove previous drivers for my old video card- which I...
The errors in computers make it miserable for their users to use them. They face so many problems when computers do not perform as intended. A very common error, which computer users can face, is the c000021a fatal system error.
This error is produced when it found by Windows NT kernel that either of the two processes Csrss.exe or Winlogon.exe has failed. Such processes could have stopped working due to many reasons like misaligned files being installed on the PC and a faulty restoration of files at the place where they were being used. In the event of such a situation, the Windows NT kernel stops the system and the stop c000021a fatal system error message is produced on the screen. This kind of a fatal exception happens when the PC can't tackle an exception and the program showing it needs to be closed.
This kind of a c000021a unknown hard error can be resolved by uninstalling the software that is not as per the needs of your PC. One can remove all the unwanted files present on the PC. An upgrade of the PC's operating system is also an alternative to restore it to its working condition and fix the stop c000021a unknown hard error.
The second solution to fix c000021a error from your computer is also very simple. You do not need to feel much hassled because of it. Just restart the computer. When the computer is booted, press the F8 button. Choose the last known good configuration and then press enter. This error generally happens when some software or hardware has been installed that is not as per the specifications of the PC. Therefore, after selecting the operating system you want for booting, the C000021a error will have been removed from your system.
However, it is better to utilize a registry cleaner software when the error still does not go away.
Windows registry includes all the information that is used by this operating system for carrying on with any operations like creation of documents. Windows Kernel uses all this information for executing the applications.
Registry cleaner software can ensure that the registry is cleaned of all the bad entries which have been causing an improper execution of files by Windows Kernel. Using this software is one of the most effective ways to fix the c000021a fatal system error. It can clean the registry without deleting any useful items from it which can lead to production of further errors.
Fix C000021a Fatal System Error is easy to do with registry cleaner. If you Scan Your Computer it will detect all the errors in your registry and safely remove them.
Dec 19, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Exception ereaderror
This seems to be a service on your computer failing to load during startup. You need to check your start-up programs for this file. To do this, click Start-->Run, type "msconfig". When the dialog windows opens, go to the "Startup" tab. Scroll through the list of applications started everytime you boot the computer. If you find "77301443.exe", disable it by unchecking the box next to its name, and click Ok.
You will be prompted to reboot your computer.
However, before rebooting your computer. It would be a good idea to run any anti-virus or anti-spyware software, clean any viruses or spyware, and then reboot the computer.
When it reboots, check for the application error again. I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 27, 2009 | Computers & Internet
Windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Jan 06, 2009 | Computers & Internet
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Opening interner explorer
Try reloading explorer again by uninstalling it and reinstalling it again.
Jun 27, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
