Question about GE Washing Machines
Rinse cycle makes a buzz sound and water remains in washer
    Scholar:
  • 106 Answers
Most likely your filter is blocked, check out where this is and clean out well. Second there could be block in your exit pump preventing the water from being pumped out. If possible call or see your dealer for help, but you could do the thing yourself. You can click on troubleshooting above in blue. There should be several solutions for your model. The washing machine companies do not tell you how to do these things, so they can send in their techs to make more money.
For new buyers - ASK WHERE THE FILTER IS, WHAT ARE THE VARIOUS CODES, SERVICE. Where is the tech sheet?
Posted on Feb 26, 2009
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Washer won't go into rinse cycle
same problem. anyone has a solution? checked the lid switch already, it seems to be intact.
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Oct 08, 2007 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
